| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: brz
shifting into 2nd
This is my first manual car so don't have much experience with shifting, but it seems difficult to shift the knob into second gear from first. It doesn't feel smooth and I kinda have to force it in there. Anyone else experience this? Is this normal?
Seρor Member
Drives: 2013 SSM DZE BRZ
How many miles are on your car? It will get easier in time. My gearbox was very tight for the first few hundred miles or so.
DEEEERP
I'm experiencing something similar, almost like its not as smooth as the other gears.
Drives: CBS BRZ limited MT
Yeah it's definitely tight for the first few hundred miles or so. I do feel some tightness when the car is cold, but once everything warms up, it feels fine
#5 | |
Drives: 2012 honda civic ex
miles before it started smoothing out,but what can ya expect from the general's crap?..ironically, the tranny in the camaro was an "aisin" japanese built!..go figure! Last edited by jmaryt; 10-16-2012 at 04:05 AM. |
Drives: 2013 BRZ Limited SWP
What car are you coming from? It's definitely a direct mechanical shift, but it's not going to be as 'easy' to shift as a 10 year old Mazda Miata.
This shifts are more difficult when the car is cold, but once it warms up it shifts nicely. Just be patient with the shifts and don't force it, it'll get easier as you drive it more.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX |
Drives: 2013 Subaru BRZ
depends on what you are coming from, the solid shift feel is one thing I like about this car, nothing like a buttery trans from a ten year old POS.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Only issue I have had is a resistant first gear shift once, so I just shifted down into second and immediately back up to first. Fixed it without issue.
Find another frs to test drive. Mine is much different than the six others that I have driven now. First and second are nit easy to get into. My clutch is much harder to push than all the others even after clutch pedal adjustment.
Sent from my SCH-I535 using Tapatalk 2 |
#10 |
Drives: '06 AM V8V Coupe
1st-2nd shift is always going to be a little harder since they have the greatest difference in gear ratio and a greater rpm drop for the synchros to match. It happens on a lot of cars.
#11 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#12 |
There are a couple other threads on upgrading the fluid which makes a difference. I'm gonna have Toyota look at mine again because it's not right.
#13 |
Drives: 86
mine is the same. 2nd is hard to engage when cold and even when warm it's a hit & miss affair. i will change gearbox oil and install Perrin shift bush and Cusco gearbox collar. hopefully it will get better.
#14 |
| shifting from 1st to 2nd | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 05-26-2016 07:15 PM |
| Backfire when shifting | canu_50 | Issues | Warranty | Recalls / TSB | 39 | 09-27-2012 01:55 AM |
| MT Shifting | n8dog11914 | Engine, Exhaust, Transmission | 4 | 08-28-2012 03:28 PM |
| Paddle Shifting | switchkick | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-14-2012 03:29 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
