Old 01-27-2014, 01:53 PM   #1
Decisis
Mechanically Unsavvy
Decisis's Avatar
Drives: 2014 BRZ Limited SWP
Notchy Shifting
Looking for some advice here since I'm not as mechanically inclined.
So I've had my car for about a couple months now only 950 miles on it. I'm noticing that the shifting feels odd and like there's something in the way (notchy) as some would put it. Is the transmission notorious for that? It's most noticeable going from 1st, 2nd, to 3rd gear.
I mean the car goes into gear fine and it drives... just kind of concerned if it'll be a growing problem. The gears were grinded once by my dad who hasn't driven stick in 5 years and the grinding lasted about 5 seconds, even then I don't think it should ruin the synchros after one incident... should I have it checked out or is this normal? If I need to I'm hoping warranty would cover something like this.
Decisis is offline   Reply With Quote
The Following User Says Thank You to Decisis For This Useful Post:
akahenry (01-29-2014)
Old 01-27-2014, 02:05 PM   #2
wparsons
wparsons's Avatar
Mine was pretty notchy for the first 1500-2000km's, it definitely gets better with some miles on it.
Mine has almost 50k km's now, and is still notchy into 2nd when it's cold, but once the fluids are warm it's fine.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Decisis (01-27-2014)
Old 01-27-2014, 02:19 PM   #3
jamesm
get a weighted shift knob. it made a world of difference, and pretty much solved the notchiness completely for me (though i already had the mtec shift springs i doubt that had an effect).
The Following 3 Users Say Thank You to jamesm For This Useful Post:
Decisis (01-27-2014), Ramster (01-29-2014), SirBrass (02-06-2014)
Old 01-27-2014, 04:13 PM   #4
Decisis
Decisis's Avatar
Was thinking about doing that! Thanks guys, looks like I'm not the only one and probably flipping over something common
Old 01-27-2014, 04:22 PM   #5
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Check this out:
http://www.ft86club.com/forums/showp...&postcount=553
Knotchy shifting solved. Another groupbuy will be happening soon per Anarachy Motive!
MightyMeeple is offline   Reply With Quote
The Following User Says Thank You to MightyMeeple For This Useful Post:
Decisis (01-28-2014)
Old 01-27-2014, 04:24 PM   #6
humfrz
Looking for some advice here since I'm not as mechanically inclined...
Hello Decisis ....
Many have reported notchy shifts, especially 1 to 2.
Does your transmission shift smoother when it's warm?
They usually smooth out with more use.
Some folks change the transmission fluid and find it shifts smoother.
A gear grind or two shouldn't mess up a transmission.
I hope you ger er smoothed out ..
Old 01-27-2014, 04:26 PM   #7
no1r
Showboater Nazi
Drives: 2014 Whiteout FR-S 6M/T
This is as designed. No worries. Heavier shift knob will help the issue as other have pointed out.
no1r is offline   Reply With Quote
The Following User Says Thank You to no1r For This Useful Post:
Old 01-27-2014, 04:30 PM   #8
wheelhaus
wheelhaus's Avatar
Part of the notchy shift feel is due to 1st, 2nd, and 3rd having triple cone synchros. They are much beefier and can handle more abuse, but as a result they feel more mechanical. The other part is because the shift mechanism is a direct mount to the transmission case, so there are no cables or additional connections to mask the mechanical feel. If the synchros are failing and not doing their job, the affected gear would begin to grind more and more frequently when selected.
wheelhaus is offline   Reply With Quote
The Following 4 Users Say Thank You to wheelhaus For This Useful Post:
chas3wba0 (01-27-2014), Decisis (01-28-2014), kevaughan (02-23-2022), RavioliG (01-05-2015)
Old 01-29-2014, 12:52 AM   #9
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
Transmission fluid change to motul gear and mtec shift springs were the cure for my notchy shifter
Sent from my Galaxy S4 using Tapatalk Pro
AllStar0419 is offline   Reply With Quote
Old 01-29-2014, 01:05 AM   #10
akyp
Drives: 2012 86
It gets better after break-in and some WOT redline shifting. Mine still has the factory fluid (because I can't find a shop that carries Motul or Pentosin) and now only the 1st gear is notchy. The rest are smooth as butter after warm up.
akyp is offline   Reply With Quote
The Following User Says Thank You to akyp For This Useful Post:
Decisis (02-07-2014)
Old 01-29-2014, 01:13 AM   #11
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Gets better with miles as most have said on here. But def helps with rear shifter bushing and tranny bushing. I have kartboy rear bushing and whiteline tranny bushing. Also totally agree with tranny fluid swap
Vlady is offline   Reply With Quote
The Following User Says Thank You to Vlady For This Useful Post:
Old 01-29-2014, 06:19 PM   #12
fazm
Drives: 2014 FR-S
A rear shifter bushing also helps smooth it out and make shifts feel a bit more solid.
fazm is offline   Reply With Quote
The Following User Says Thank You to fazm For This Useful Post:
Old 01-29-2014, 06:32 PM   #13
Ramster
Ramster's Avatar
Drives: Subaru BRZ Limited
Originally Posted by MightyMeeple View Post
Check this out:
I just received my from the group buy and it makes a HUGE difference. I would definitely recommend one of these along with a fluid change as someone already suggested.
The knotchy shifting isn't completely gone, but it's a non issue now in my opinion.
Ramster is offline   Reply With Quote
The Following User Says Thank You to Ramster For This Useful Post:
Old 01-30-2014, 08:56 AM   #14
no1r
Showboater Nazi
I am convinced that what feeling is left, is just how its designed. No reason to worry anymore That said, feels good, worth the weight.
shifting into 2nd cantaloupe BRZ First-Gen (2012+) — General Topics 63 06-23-2014 04:47 PM
notchy/gritty transmission. every gear grinding prest1ge Engine, Exhaust, Transmission 41 12-09-2012 06:45 PM
Now 4th gear is notchy Yruyur Engine, Exhaust, Transmission 38 11-15-2012 09:07 PM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 03:28 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
