Old 10-26-2012, 12:52 PM   #1
Yruyur
Yruyur's Avatar
Now 4th gear is notchy
My first and second gear have been notchy for a few thousand miles now but yesterday I had 4th act up about 5 times. I missed the gear once. The other times it felt like there were to saw blades that I had cut my way between. Think I need to do a transmission fluid upgrade.
Old 10-26-2012, 12:58 PM   #2
djliquidsteele
Drives: Scion FR-S
Just had my fluid changed to Pentosin. The first day I couldn't really tell a difference, but it seems it has worked into everything and is smooth as butter. Well worth the price of admission.
djliquidsteele is offline   Reply With Quote
Old 10-26-2012, 01:12 PM   #3
Yruyur
Yruyur's Avatar
I'm gonna have to use this stuff. Another local member was telling me about it.
Old 10-26-2012, 04:57 PM   #4
GenesisAZ
Drives: 2013 Hyundai Genesis Coupe 2.0T
You could try a Friction Modifier before doing a complete fluid change.. This is the stuff the mazdaspeed guys were using: http://www.fordracingparts.com/parts...tKeyField=6930
GenesisAZ is offline   Reply With Quote
Old 10-26-2012, 05:41 PM   #5
Yruyur
Yruyur's Avatar
Thanks. I'll look into it.
Old 10-30-2012, 12:33 AM   #6
Yruyur
Yruyur's Avatar
5th is starting up now Wtf. Have an appointment on Monday. Going to make sure I'm in the shoo while they are working on it so I can see the fluid level and clutch.
Sent from my flux capacitor using Taptalk
Old 11-05-2012, 02:45 PM   #7
Yruyur
Yruyur's Avatar
Been at the dealership since 8 this morning. They are thinking a new transmission and or clutch is needed. They have been on the phone all day with Toyota. They agree the 4th gear grinding is not normal. They are dropping the fluid first per Toyota to inspect it then will inspect the clutch. They don't know how long it will take to get either of them delivered yet.
Old 11-05-2012, 02:48 PM   #8
gmookher
mileage?
gmookher is offline   Reply With Quote
Old 11-05-2012, 02:48 PM   #9
gmookher
FM is useless in our cars
Old 11-05-2012, 02:50 PM   #10
Yruyur
Yruyur's Avatar
Originally Posted by gmookher View Post
mileage?
13,000
Old 11-05-2012, 02:55 PM   #11
canu_50
canu_50's Avatar
Drives: Scion fr-s
I personnally always take out the OEM fluid, mine litterally stayed 3 days in the car. I am now running redline and with my Billetproshop shifter since 9000km and no issue on my transmission and i have been drifting,roadracing the shatz out of the car.
canu_50 is offline   Reply With Quote
Old 11-05-2012, 03:05 PM   #12
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
What are your driving habits? Be cautious with your warranty coverage; its easy for them to call abuse on parts like the clutch/transmission.
chulooz is offline   Reply With Quote
Old 11-05-2012, 03:07 PM   #13
Calum
That Guy
Drives: 2013 asphalt FRS MT
Friction modifiers are normally used to help limited slip diffs, which our tranny doesn't have.
Old 11-05-2012, 04:38 PM   #14
Yruyur
Yruyur's Avatar
Just got the disclaimer they are going to charge me for labor and parts if there is user damage to the clutch. Over a grand. Going to drop the tranny. Was shocked at how thin the tranny fluid is..like water.
notchy/gritty transmission. every gear grinding prest1ge Engine, Exhaust, Transmission 41 12-09-2012 06:45 PM
50 mph 5th gear 3k Rpm? _F-R-S_ Issues | Warranty | Recalls / TSB 8 09-20-2012 05:19 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
