Old 11-20-2013, 04:39 AM   #15
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Nvm.. do I push in the hub/rotor assembly and tighten it?
Sent from my SGH-T999 using Tapatalk
hanabie is offline   Reply With Quote
Old 11-20-2013, 10:42 PM   #16
acx23
Drives: 2013 FRS (Silver)
Sounds like you might have the 14mm camber bolt. If that's the case, that needs to be placed on the bottom slot instead of the top slot. And you need to set it at max camber.
16mm camber bolt is needed for the top slot.
Originally Posted by hanabie View Post
I cant mount on the other side. My slotted hole is too small the camber bolt.
acx23 is offline   Reply With Quote
Old 11-20-2013, 10:48 PM   #17
hanabie
hanabie's Avatar
I have 16mm but slotted upper hole. It was mentioned on the other thread. I just checked this morning
Old 11-20-2013, 11:08 PM   #18
acx23
I can't tell if your bottom bolt is loose based on your pictures, but they needs to be loosen if they're not. I haven't had any experiences the tab washer so hopefully you'll figure it out soon. Good luck!
Old 11-21-2013, 12:25 PM   #19
hanabie
hanabie's Avatar
My problem is solved! Thanks everyone
Old 11-21-2013, 08:48 PM   #20
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
So others can learn from this....what was it that you weren't doing right?
Fizz is offline   Reply With Quote
Old 11-21-2013, 11:46 PM   #21
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
there is an arrow on the bolt head. for max neg camber it needs to point towards the shock. and the tab of the washer under the head pointed in the same direction.
garfull is offline   Reply With Quote
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
