Old 11-16-2013, 07:00 PM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Help camber bolts installation
Is this the correct orientation? Do I need that plate showed on the second picture? It seems it does not fit well to my struts. Thanks
Sent from my SGH-T999 using Tapatalk
hanabie is offline   Reply With Quote
Old 11-16-2013, 07:42 PM   #2
Doobster
Doobster's Avatar
Drives: FRS
The tab should point in the direction you want the wheel to go. An example would be towards the outside for positive camber and towards inside for negative adjustment, you want it at 3 or 9 o'clock.
As for that spacer washer piece, I have never seen one of those on a front camber bolt kit, could be a lockout for an oem camber bolt, I wouldnt worry about it. GL
Doobster is offline   Reply With Quote
The Following User Says Thank You to Doobster For This Useful Post:
hanabie (11-16-2013)
Old 11-16-2013, 07:52 PM   #3
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
that plate is not for this car. that tab should be facing the engine not vertical. if neg camber is what you are after. If there is a arrow on the bolt head by the tab that arrow needs to face the tire if you want max neg camber.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Old 11-16-2013, 07:52 PM   #4
hanabie
hanabie's Avatar
Thanks alot
Old 11-16-2013, 07:59 PM   #5
hanabie
hanabie's Avatar
But the adjuster was blocked by the strut assembly. See picture 1. Is that ok to set up that way? I want max neg camber.
Old 11-16-2013, 08:07 PM   #6
hanabie
hanabie's Avatar
I only can max with this. Is that ok? Thanks. Im looking for max neg camber
Old 11-16-2013, 08:38 PM   #7
Doobster
Doobster's Avatar
Drives: FRS
That will do for now, but if you really wanted the full adjustment it's best to have it directly horizontal, if ya can cut the tab or trim the washer and remember where it was could be a solution for that situation
hanabie (11-17-2013)
Old 11-17-2013, 09:37 PM   #8
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If it gets you the desired camber you were after, just leave it as it is. If not, get some camber tops instead.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Old 11-17-2013, 09:43 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
This post made me realize there is no DIY for OEM camber bolt install. Someone should post one up
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 11-17-2013, 10:05 PM   #10
Doobster
Doobster's Avatar
Drives: FRS
"It puts the bolt in the hole"
Old 11-19-2013, 09:43 AM   #11
acx23
Drives: 2013 FRS (Silver)
According to Whiteline, you have it on backwards.
http://www.whiteline.com.au/docs/ins...uides/Z201.pdf
acx23 is offline   Reply With Quote
Old 11-20-2013, 03:57 AM   #12
hanabie
hanabie's Avatar
I cant mount on the other side. My slotted hole is too small the camber bolt.
Old 11-20-2013, 03:58 AM   #13
hanabie
hanabie's Avatar
HELP!! I CANT GET NEGATIVE CAMBER. Only zero or positive! Any ideas??!! I faced inside my washer.
Old 11-20-2013, 03:59 AM   #14
hanabie
hanabie's Avatar
Do I need to lose strut top 3 nuts to adjust negative?
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
