Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 08-19-2022, 03:32 AM   #15
allowe
allowe's Avatar
Originally Posted by villainous_frx View Post
Having played CS:GO with this fella, I know for a fact he's a taker! Always takes a teammate drop but never gives them
It’s called baiting bb. You either bait or be baited :P
allowe is offline   Reply With Quote
Old 08-19-2022, 10:09 AM   #16
jordan7831
Drives: 2016 Halo FRS
So sorry to jump in on this one. Is there anyone around the 404/401 area that is a strong recommendation?
Originally Posted by Mr.ac View Post
My butt dnyo didn't like it
jordan7831 is offline   Reply With Quote
Old 08-20-2022, 07:53 PM   #17
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Rent a transmission jack for $20/day if you are having problems. Make sure your alignment tool centered the clutch well. Rotate the output shaft slightly using the driveshaft to get the splines to line up well. Use the bolts to help pull the transmission to the motor, but it will only pop into position when the spines are perfectly aligned, so a transmission jack and twisting the driveshaft while in gear really helps.
I purchased a tranny jack adapter for my floor jack from Princess Auto.
Unfortunately with my car on four jack stands the unit would lower the tranny but not enough to clear the cars bellypan. The car should have been a couple inches higher. We ended up lowering the jack and muscling the tranny off the jack onto the ground and dragging it out out from under the car. To re-install we just put the tranny on a mat and dragged it back under the car where two of us lifted it into position with some massive rocking effort to get it up against the bell housing.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 08-20-2022, 09:41 PM   #18
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I typically just lay the transmission on my stomach with cardboard as protection and bench it into position. Taking it out is the same process of lowering it to my chest and sliding it to the floor between my legs. Luckily the transmission is light.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
NoHaveMSG (08-20-2022)
Old 08-20-2022, 09:44 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Similar to how I did mine. I balanced it on a regular floor jack, held on to it and raised it up a bit. Then lifted it into position.
Old 08-21-2022, 03:36 AM   #20
Ultramaroon
not playing cards
Ultramaroon's Avatar
I don't even use cardboard. Just bench press it.
Old 08-22-2022, 03:39 PM   #21
Thought you would just stay outside the car, reach under and push it up.
Ultramaroon (08-22-2022)
Old 08-22-2022, 03:56 PM   #22
Ultramaroon
not playing cards
Old age takes its toll.
NoHaveMSG (08-22-2022), villainous_frx (08-22-2022)
Old 08-22-2022, 04:01 PM   #23
So you can't manhandle trannys like you used to eh.
NoHaveMSG (08-22-2022), soundman98 (08-22-2022)
Old 08-22-2022, 04:52 PM   #24
Ultramaroon
not playing cards
Takes more time to align the shaft.
Old 08-22-2022, 07:09 PM   #25
Muskoka800
XXL 52” 66 year old chest. I can barely fit under there myself without a dolly, let alone with a tranny on top of me.
You must be slender youthful types.
Actually my Buddy and I co-benched it up off the ground. We’re getting to old for this fun.
The Following User Says Thank You to Muskoka800 For This Useful Post:
Tcoat (08-22-2022)
Old 08-22-2022, 09:22 PM   #26
soundman98
ProCrastinationConsultant
soundman98's Avatar
i dunno, a dolly, a tranny and a double-x-l guy in a garage...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Ultramaroon (08-23-2022), villainous_frx (08-22-2022)
Broken suspension bolt Rocketman Issues | Warranty | Recalls / TSB 4 03-25-2021 07:09 PM
Broken ignition coil bolt UNCC_BRZ Engine, Exhaust, Transmission 9 03-19-2019 11:19 PM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 06:31 AM
Broken Assembly Bolt VIP BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-18-2016 11:02 PM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 01:48 AM
