Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 08-18-2022, 01:19 AM   #1
allowe
allowe's Avatar
LF: a good auto shop in the GTA area
Looking for a good shop that knows how to do a clutch job on the FRS
Edit: found one thanks to Vilanous_frx it’s XIII Motorsport.
allowe is offline   Reply With Quote
The Following User Says Thank You to allowe For This Useful Post:
Ultramaroon (08-19-2022)
Old 08-18-2022, 02:23 AM   #2
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
XIII Motorsport, NV Auto, Apex Auto.
If you want to venture to London... Rob Clarke Automotive and Ron's Quality Auto are both great shops that I have used.
villainous_frx is offline   Reply With Quote
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
allowe (08-18-2022), Tcoat (08-18-2022)
Old 08-18-2022, 07:28 AM   #3
Is that the Ron's on Wharncliffe? If so they were the guys that replaced the engine in my Talon TSi when I was stupid and blew it up. Great work at a reasonable price (well 20 years ago at any rate). Bit of a haul from Mississauga though.
Old 08-18-2022, 07:31 AM   #4
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Contact Alex at Adrena Garage, Speers Road, Oakville.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Tcoat (08-18-2022)
Old 08-18-2022, 12:43 PM   #5
villainous_frx
Off to the track!
Yep same shop. Great guys and very reasonable pricing. Definitely a trek from the GTA, but hey figured I would put them out there since they did some transmission work on my old WRX
The Following User Says Thank You to villainous_frx For This Useful Post:
Tcoat (08-18-2022)
Old 08-18-2022, 12:50 PM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Rent a transmission jack for $20/day if you are having problems. Make sure your alignment tool centered the clutch well. Rotate the output shaft slightly using the driveshaft to get the splines to line up well. Use the bolts to help pull the transmission to the motor, but it will only pop into position when the spines are perfectly aligned, so a transmission jack and twisting the driveshaft while in gear really helps.
Old 08-18-2022, 01:59 PM   #7
He hasn't even managed to get it apart much less be in a position to put it back together again.
Irace86.2.0 (08-18-2022)
Old 08-18-2022, 02:35 PM   #8
Irace86.2.0
Awww, I read that wrong. I thought he got it off and was trying to put it back together now when he snapped a bolt.
It is odd to snap a bolt putting it back together when it was never really apart completely, so I think that is why it didn't register correctly in my brain.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
humfrz (08-18-2022), Tcoat (08-18-2022)
Old 08-18-2022, 04:32 PM   #9
allowe
allowe's Avatar
LF: a mechanic that can do a clutch job and remove broken starter bolt
I love u dude, I got 13 Motorsport to work on it for me
Old 08-18-2022, 05:27 PM   #10
humfrz
Old age catchen up you?
Old 08-18-2022, 07:56 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by allowe View Post
Please close, I got what I needed
Please close
um, this isn't facebook. this will not be closed. or deleted.
posts are maintained so there's a database of past questions so when some other poor soul in the same scenario starts searching for answers, your previous question ever so kindly helps them out without ever needing to repeat the same question again!
unless of course the OP decides to edit their post so it's of no use to anyone else ever again.
nuking things might work for ADHD facebook and instagram, but the rest of the internet thrives off building on others past experience. it's also how and why everyone wants to go to college, which is also coincidently built on the concept of fast-tracking feeding previous humans knowledge into individuals to make those individuals become what most define as 'intelligent'.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Tcoat (08-19-2022), Ultramaroon (08-19-2022), villainous_frx (08-19-2022)
Old 08-19-2022, 02:04 AM   #12
Ultramaroon
not playing cards
Ultramaroon's Avatar
Some are givers.
Some are takers.
soundman98 (08-19-2022)
Old 08-19-2022, 02:07 AM   #13
villainous_frx
Off to the track!
Some are givers.
Some are takers.
Having played CS:GO with this fella, I know for a fact he's a taker! Always takes a teammate drop but never gives them
Old 08-19-2022, 02:32 AM   #14
allowe
allowe's Avatar
I didn’t think it would’ve been useful to keep the post up but you’re right. I updated the post. It’s not the same as the original post but it’s close enough, good call.
Broken suspension bolt Rocketman Issues | Warranty | Recalls / TSB 4 03-25-2021 06:09 PM
Broken ignition coil bolt UNCC_BRZ Engine, Exhaust, Transmission 9 03-19-2019 10:19 PM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
Broken Assembly Bolt VIP BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-18-2016 10:02 PM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 12:48 AM
