Old 04-14-2016, 03:00 PM   #1
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Broken Assembly Bolt
I’m working on a set of old Work Eroline DH’s and a few of the old assembly bolts broke on removal, Thought I would get some input.
First off, they are Welded two piece wheel so the assembly bolts are purely cosmetic/ Not structurally holding the wheels together.
I have tried soaking them in WD-40 overnight and grabbing the reverse end of the bolt poking out from the back with some needle noses without success.
Also my attempts with a SpeedOut “Extractor” have failed (I was unable to bore into the bolt to create the indent for lifting)
- I think, a nut could be welded to the reverse end but I’m not equipped for this job
Anyone Know a Fabricator/Welder or Shop in the Los Angeles area that could help me out with these?
Or any other ideas for getting these dang things out?
VIP BRZ is offline   Reply With Quote
Old 04-14-2016, 09:25 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
The only way is to drill it out. You can try doing it yourself, use a spot drill frist to center it as best you can. Then use a drill that just about the same size of the bolt. Hopefully you'll get it.
If not find the next size up tap/drill.
They way I would do it is to use an industrial size drill press. Something that won't wonder out of center.
Old 04-15-2016, 10:43 AM   #3
VIP BRZ
VIP BRZ's Avatar
Yea i cant drill into the bolt with my hand drill at home it too hard, I'll have to take it into a local machine shop.
Old 04-16-2016, 01:17 AM   #4
Ashikabi
Ashikabi's Avatar
They will be able to handle it. Your drill bit may be dull. Hand drills wreck drill bits pretty quick
Old 04-18-2016, 10:42 AM   #5
VIP BRZ
VIP BRZ's Avatar
Quick update on this, took the wheels into a shop this weekend and he was able to drill them out and re-thread the holes. they are a bit loose but again cosmetic bolt so ill just use some sealant or something to assure they wont come flying out.
This is the shop that was able to help me. on a saturday.
David and Sunny Auto
http://www.yelp.com/biz/david-and-su...to-los-angeles
Old 04-18-2016, 10:02 PM   #6
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Awesome. Good to hear. Yep some loctie would work.
My car got BROKEN into. Hiros86 Northern California 25 02-25-2014 11:33 AM
Rust on bolt on headlight assembly slicktop Cosmetic Modification (Interior/Exterior/Lighting) 0 12-13-2013 09:11 AM
Still not broken in Drftfan Scion FR-S / Toyota 86 GT86 General Forum 38 06-13-2013 07:51 PM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 12:48 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
