#15 |
#16 |
Drives: 2016 Halo FRS
So sorry to jump in on this one. Is there anyone around the 404/401 area that is a strong recommendation?
#17 | |
Drives: 2016 Scion FRS Release Series 2#439
Unfortunately with my car on four jack stands the unit would lower the tranny but not enough to clear the cars bellypan. The car should have been a couple inches higher. We ended up lowering the jack and muscling the tranny off the jack onto the ground and dragging it out out from under the car. To re-install we just put the tranny on a mat and dragged it back under the car where two of us lifted it into position with some massive rocking effort to get it up against the bell housing.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#18 | |
Drives: Q5 + BRZ + M796
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | NoHaveMSG (08-20-2022) |
#19 | |
Drives: Crapcan
Similar to how I did mine. I balanced it on a regular floor jack, held on to it and raised it up a bit. Then lifted it into position.
#20 |
I don't even use cardboard. Just bench press it.
#21 |
Thought you would just stay outside the car, reach under and push it up.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (08-22-2022) |
#22 |
Old age takes its toll.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (08-22-2022), villainous_frx (08-22-2022) |
#23 |
So you can't manhandle trannys like you used to eh.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (08-22-2022), soundman98 (08-22-2022) |
#24 |
Takes more time to align the shaft.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (08-22-2022), soundman98 (08-22-2022) |
#25 | |
You must be slender youthful types. ![]() Actually my Buddy and I co-benched it up off the ground. We’re getting to old for this fun.
| The Following User Says Thank You to Muskoka800 For This Useful Post: | Tcoat (08-22-2022) |
#26 |
ProCrastinationConsultant
i dunno, a dolly, a tranny and a double-x-l guy in a garage...
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Ultramaroon (08-23-2022), villainous_frx (08-22-2022) |
| Broken suspension bolt | Rocketman | Issues | Warranty | Recalls / TSB | 4 | 03-25-2021 07:09 PM |
| Broken ignition coil bolt | UNCC_BRZ | Engine, Exhaust, Transmission | 9 | 03-19-2019 11:19 PM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 06:31 AM |
| Broken Assembly Bolt | VIP BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-18-2016 11:02 PM |
| Exhaust Tips & Broken Bolt | eriktherod | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-07-2012 01:48 AM |
