#15 |
JHerbert Racing
Drives: 2013 Scion FRS
Here is the comparison/research.
OFF THE LINE PERFORMANCE COIL ADAPTER HARNESS SET https://www.ftspeed.com/part/fr-s-br...t#.YYUVgJ7MKUk In mid-2014 Subaru/Toyota upgraded the coils to a "more resilient" design. The ad for the coil adapters says 2017+ but as you can see in the links/pictures, the 2017 coil is the same part number as the mid-2014 refresh. Notice the (supersessions) in the 2013 picture. I believe these coils were also updated while maintaining the 2013 connector. I have no proof of this however Subaru/Toyota knew they were an issue according to a TSB in 2012. See this thread for more info : https://www.ft86club.com/forums/showthread.php?t=21868 2013 part number: https://parts.subaru.com/p/Subaru_20...2433AA652.html ![]() 2015 part number: https://parts.subaru.com/p/Subaru_20...2433AA730.html ![]() 2018 part number: https://parts.subaru.com/p/Subaru_20...2433AA730.html ![]() The side by side comparison shows a definite change in design other than the connector as the overall dimensions and designs were altered. ![]() ![]() ![]() Hope this helps. Its November and the beginning of the off-season. I will be back on track with the car in April. We will see how the 2015+ coils hold up.
#16 |
Drives: 2013 frs base
Thank you for the comparison though, I wish you had an xray machine. It would be nice to know the internal changes. More insulation? More windings? Are they fortified with nutrients to produce a hotter spark?
#17 | |
JHerbert Racing
If any of the 2015+ fail, I will cut both designs in half to compare.
#18 |
JHerbert Racing
My 2013 fired right up with the Off the Line conversion harness and 2015+ coil packs. Zero issues with install.
#19 | |
#20 |
Drives: Crapcan
Good to hear. I have been considering this option even though I haven't had too much of an issue. I do have like 5 spare coils so I wasn't in a rush to try it.
| Upgrade 2013 to newest coil pack design and connectors | jflogerzi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-19-2026 11:01 PM |
| Coil Pack upgrade 2015 BRZ | Mad-BRZ | BRZ First-Gen (2012+) — General Topics | 2 | 04-14-2019 11:53 AM |
| Coil pack options | ROADRACER | Engine, Exhaust, Transmission | 14 | 12-24-2018 02:33 AM |
| Coil ignition pack | D86Ellis | Issues | Warranty | Recalls / TSB | 7 | 09-20-2016 02:01 AM |
| Coil pack part numbers? | feldy | Engine, Exhaust, Transmission | 6 | 03-11-2014 11:31 AM |
