Old 11-05-2021, 07:34 AM   #15
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Here is the comparison/research.
OFF THE LINE PERFORMANCE COIL ADAPTER HARNESS SET
https://www.ftspeed.com/part/fr-s-br...t#.YYUVgJ7MKUk
In mid-2014 Subaru/Toyota upgraded the coils to a "more resilient" design. The ad for the coil adapters says 2017+ but as you can see in the links/pictures, the 2017 coil is the same part number as the mid-2014 refresh.
Notice the (supersessions) in the 2013 picture. I believe these coils were also updated while maintaining the 2013 connector. I have no proof of this however Subaru/Toyota knew they were an issue according to a TSB in 2012. See this thread for more info :
https://www.ft86club.com/forums/showthread.php?t=21868
2013 part number:
https://parts.subaru.com/p/Subaru_20...2433AA652.html
2015 part number:
https://parts.subaru.com/p/Subaru_20...2433AA730.html
2018 part number:
The side by side comparison shows a definite change in design other than the connector as the overall dimensions and designs were altered.
Hope this helps. Its November and the beginning of the off-season. I will be back on track with the car in April. We will see how the 2015+ coils hold up.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
bcj (01-05-2022)
Old 11-05-2021, 09:07 AM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Thank you for the comparison though, I wish you had an xray machine. It would be nice to know the internal changes. More insulation? More windings? Are they fortified with nutrients to produce a hotter spark?
Old 11-05-2021, 09:24 AM   #17
Takumi788
JHerbert Racing
Takumi788's Avatar
The TSB and concerns had to do with component life span. Not performance. I highly doubt there is any performance gain at all. Just longevity.
If any of the 2015+ fail, I will cut both designs in half to compare.
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
blsfrs (11-06-2021), Capt Spaulding (11-05-2021)
Old 01-05-2022, 06:52 AM   #18
Takumi788
JHerbert Racing
Takumi788's Avatar
My 2013 fired right up with the Off the Line conversion harness and 2015+ coil packs. Zero issues with install.
bcj (01-05-2022), NoHaveMSG (01-05-2022)
Old 01-05-2022, 07:03 PM   #19
Grady
Grady's Avatar
Originally Posted by Joon525 View Post
Just putting this out here for an additional source of materials for anyone in the same situation as you.
https://www.iwireservices.com/produc...or-brz-and-frs
That is the way to do it. Crimping connectors is easy and this does not add another connection to fail like adapters.
Old 01-05-2022, 10:21 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Good to hear. I have been considering this option even though I haven't had too much of an issue. I do have like 5 spare coils so I wasn't in a rush to try it.
Upgrade 2013 to newest coil pack design and connectors jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-07-2020 03:13 PM
Coil Pack upgrade 2015 BRZ Mad-BRZ BRZ First-Gen (2012+) — General Topics 2 04-14-2019 11:53 AM
Coil pack options ROADRACER Engine, Exhaust, Transmission 14 12-24-2018 02:33 AM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 02:01 AM
Coil pack part numbers? feldy Engine, Exhaust, Transmission 6 03-11-2014 11:31 AM
