Old 02-11-2020, 10:45 PM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
"ECU IG1"
"ECU IG2"
"ECU ACC"
are all circuits that very commonly come on/off with a key. i believe ignition 2 is the radio power circuit, so it's easy to know if it's working.
Kaily (02-11-2020)
Old 02-12-2020, 12:25 AM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Looks like OP may have had electrical problems in the past? Been a while but may be related.
https://www.ft86club.com/forums/showthread.php?t=113496
Spuds is online now   Reply With Quote
humfrz (02-12-2020), soundman98 (02-12-2020)
Old 02-13-2020, 06:20 AM   #17
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
So to speak to the 500 rpm, my WRX had similar symptoms when I did my exhaust, intake, and EBCS. I was surprised to learn how much the MAF sensor was tied to ABS, TCS (wheel speed sensor). Although I agree that your wiring to the wiper fuse is puzzling, maybe clean your MAF sensor with some MAF cleaner. But maybe your car went to limp mode because of the questionable wiring. This is why I'm a mechanical guy, I despise electrics lol.
Sent from my Pixel 2 using Tapatalk
ROFL it's Waffle is offline   Reply With Quote
Old 02-13-2020, 03:04 PM   #18
p1l0t
p1l0t's Avatar
It doesn't take as long as people think to pull out sensors and test their resistance. Tedious but it may be the solution (although it could be as simple as plugs, fuel injector cleaner, or an air filter!) I had a similar problem with my Fiancée's Impreza, low RPMs, occasional cam position sensor, and rarely a cyclinder misfire code. I replaced on cam sensor that didn't read out the right ohms and that made it better but it was still a little wierd with the RPMs just less codes thrown so I ran a bottle of injector cleaner and the car drives normally again. The issues can be the same or different but the approach is the same. Test anything that might be a problem and fix the cheap possibilities first.
Old 02-13-2020, 10:52 PM   #19
soundman98
soundman98's Avatar
you know, everyone that's contracted me to do electrical work that says this phrase is always the type that firmly believes that everything can be fixed with only duct tape, baling wire, and wd40.
duct tape is conductive, baling wire has a high resistance, and wd40 is flammable. none of those things should be mixed with electricity...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (02-14-2020), p1l0t (02-13-2020)
Old 02-14-2020, 09:22 AM   #20
ROFL it's Waffle
(<-- damn dude, smile a little) The aluminum stuff used to seal the seams on duct work is without question conductive. General purpose duct tape is not conductive, but it is also not insulated (doesn't protect against getting zapped). It's just not advisable to use because it offers minimal fire protection under a load.
Old 02-14-2020, 04:25 PM   #21
humfrz
Bubba says you're WRONG!
humfrz
Old 02-14-2020, 08:48 PM   #22
soundman98
soundman98's Avatar
general purpose duct tape is in fact conductive. i made an amplifier very unhappy playing with some speakers trying to use duct tape to seal off the back side of the speakers(putting tape over/across the terminals), the speakers started audibly distorting from the short. i've also ran into it a few times in residential wiring, after it causes issues that no one else can figure out...
i'm talking about this stuff
put an ohm meter on the adhesive part of your roll
Old 02-14-2020, 08:50 PM   #23
soundman98
soundman98's Avatar
humfrz
nothing quite says wise and experienced like full tattoo sleeves and a scraggly beard!
i don't mind. bubba's keep me employed.
humfrz (02-15-2020)
Old 02-15-2020, 06:51 PM   #24
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Originally Posted by Kaily View Post
The windshield wiper fuse was used because for some reason literally every other fuse we tried wouldn't work--we tried all the fuses for things that should have been off if the car was off but the airlift system would be turn on even thought they keys are not in the car and the car is not on..
Going from bad to worse.
PetrolioBenzina is offline   Reply With Quote
Old 02-15-2020, 07:30 PM   #25
mrg666
pessimistic skeptic
mrg666's Avatar
Recently its been at 500 and the car shakes as if its about to stall.
check engine and traction lights.
car just shut off. It turned back on without any trouble.
I solved those symptoms with a MAF sensor replacement. The CEL was P0172 (system too rich).
I had similar trouble later but this time CEL was P0304 (cylinder misfire) with additional symptom of engine shaking, not just rough idle. That was fixed with replacing the valve springs.
Get an OBDII reader and post the CEL number here so that you can get better help.
BTW, normal warm idle is ~800 rpm. If AC or radiator fans are on, idle goes closer to 1000 rpm.
The Following User Says Thank You to mrg666 For This Useful Post:
p1l0t (02-17-2020)
Old 02-16-2020, 11:59 PM   #26
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Keep it all OE , just do a K&N /TRD drop in air filter , use as good of lubricants as you can afford , change engine oil every 5k miles roughly, and put in the highest 91-94 octane fuel as you can!
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 02-18-2020, 01:36 AM   #27
jflogerzi
jflogerzi's Avatar
My car seemed to have a dramatic cold start at about 2500, then it usually calmed down to about 1000.
That's normal with a stock ECU tune. Does this to get cat up to temp
2013 Series 10 FRS #553
Odd noise when idling? Terruko Issues | Warranty | Recalls / TSB 29 10-16-2016 08:09 PM
6 speed m/t idling low Gt86_nick Engine, Exhaust, Transmission 1 01-28-2014 08:54 PM
Idling Issue ericmpena Issues | Warranty | Recalls / TSB 1 11-01-2013 01:21 AM
High idling on new FR-S ndsleep612 Issues | Warranty | Recalls / TSB 19 07-27-2013 11:06 AM
Idling/RPM question Crackseed Hawaii 3 02-25-2013 12:54 AM
