#15 |
ProCrastinationConsultant
"ECU IG1"
"ECU IG2" "ECU ACC" are all circuits that very commonly come on/off with a key. i believe ignition 2 is the radio power circuit, so it's easy to know if it's working.
| The Following User Says Thank You to soundman98 For This Useful Post: | Kaily (02-11-2020) |
#16 |
The Dictater
Drives: '13 Red Scion FRS
Looks like OP may have had electrical problems in the past? Been a while but may be related.
https://www.ft86club.com/forums/showthread.php?t=113496 |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | humfrz (02-11-2020), soundman98 (02-12-2020) |
#17 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
So to speak to the 500 rpm, my WRX had similar symptoms when I did my exhaust, intake, and EBCS. I was surprised to learn how much the MAF sensor was tied to ABS, TCS (wheel speed sensor). Although I agree that your wiring to the wiper fuse is puzzling, maybe clean your MAF sensor with some MAF cleaner. But maybe your car went to limp mode because of the questionable wiring. This is why I'm a mechanical guy, I despise electrics lol.
Sent from my Pixel 2 using Tapatalk |
#18 | |
Sent from my SM-G975U using Tapatalk |
#19 | |
duct tape is conductive, baling wire has a high resistance, and wd40 is flammable. none of those things should be mixed with electricity...
#20 |
(<-- damn dude, smile a little) The aluminum stuff used to seal the seams on duct work is without question conductive. General purpose duct tape is not conductive, but it is also not insulated (doesn't protect against getting zapped). It's just not advisable to use because it offers minimal fire protection under a load.
#21 | |
![]() humfrz |
#22 | |
i'm talking about this stuff ![]() put an ohm meter on the adhesive part of your roll
#23 |
nothing quite says wise and experienced like full tattoo sleeves and a scraggly beard!
i don't mind. bubba's keep me employed.
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (02-14-2020) |
#24 | |
Drives: 17 86
#25 | |
pessimistic skeptic
I had similar trouble later but this time CEL was P0304 (cylinder misfire) with additional symptom of engine shaking, not just rough idle. That was fixed with replacing the valve springs. Get an OBDII reader and post the CEL number here so that you can get better help. BTW, normal warm idle is ~800 rpm. If AC or radiator fans are on, idle goes closer to 1000 rpm. |
| The Following User Says Thank You to mrg666 For This Useful Post: | p1l0t (02-16-2020) |
#26 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Keep it all OE , just do a K&N /TRD drop in air filter , use as good of lubricants as you can afford , change engine oil every 5k miles roughly, and put in the highest 91-94 octane fuel as you can!
Math is like Love, simple idea at first that quickly gets complicated
#27 | |
2013 Series 10 FRS #553
| Odd noise when idling? | Terruko | Issues | Warranty | Recalls / TSB | 29 | 10-16-2016 07:09 PM |
| 6 speed m/t idling low | Gt86_nick | Engine, Exhaust, Transmission | 1 | 01-28-2014 07:54 PM |
| Idling Issue | ericmpena | Issues | Warranty | Recalls / TSB | 1 | 11-01-2013 12:21 AM |
| High idling on new FR-S | ndsleep612 | Issues | Warranty | Recalls / TSB | 19 | 07-27-2013 10:06 AM |
| Idling/RPM question | Crackseed | Hawaii | 3 | 02-24-2013 11:54 PM |
