#15 |
Drives: 2016 Subaru BRZ Premium
So I am having second thoughts about selling my wheels. I have a set of ST coils at home, and was wondering what else I needed to fit the 18x9.5s with 245 tires? I know I need camber plates, but what are the reccomended specs?
#16 | |
Drives: 2015 BRZ
Here is a thread to help you out. http://www.ft86club.com/forums/showthread.php?t=60405 |
#17 | |
Drives: 2015 Firestorm FRS
So 18x9.5+45 with 255/35/18 dont have rubbing issues with tein flex z/ bc coils?
Thanks Quote:
#18 |
Drives: 2015 BRZ
Yes, that is correct. The main issue with that size on stock suspension is the spring perches. With coilovers it eliminates those perches so you have more clearance. You should not have any issues just keep in mind that you may not able be able to run a lot of camber in the front depending on tire size.
#19 | |
Yes. My set up now is -3 front -2.5 rear.
Now i have blox lca, im gonna do like stockish maybe -1.5 front -1 rear. Quote:
#20 |
Drives: 2014 GT86
"stockish" is 0 front. rather understeer-ish.
| Wheel Spec Recommendations (Subaru BRZ) | scottryan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 05-25-2018 04:56 PM |
| Personal wheel spec questions??? | itsalexramos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-24-2018 08:12 PM |
| Torque spec for steering wheel nut? | zooki | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-11-2015 02:14 PM |
| RB Wheel spec help | Jrryjms07 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 07-14-2014 03:18 AM |
| Aggressive wheel spec info | 2K13BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-31-2013 02:57 PM |
