Financial Distress
Drives: 2017 GT86 325WHP
Wheel Spec Recommendations (Subaru BRZ)
Apologies in advance because I just recently bought my BRZ and am unfamiliar with a lot of the wheel specs.
Car is 2013 Subaru BRZ stock everything, if I wanted to run a 19" wheel in the rear (Say, 10.5" in width) and an 18" wheel in the front (9 to 9.5" in width), what would I be looking for in terms of making sure it fits? (Suspension, offset, etc.) Thanks! |
Ooof.
What are your goals with your car? Show car? Daily driver? 19x10.5 is....a lot. - Andrew |
#3 | |
Financial Distress
thanks for the response by the way! |
Drives: 86
This thread will help - http://www.ft86club.com/forums/showthread.php?t=7535
LMGTFY
Drives: 13 FRS, 91 Miata
What's the look you going for?
This Or This....
Drives: 2014 GT86
x808drifter: probably none of these two. They are not welded suspension land-scraping slammed and camber at least 10 degrees less then planned
Financial Distress
x808drifter
Damn those don't look photoshopped at all
#8 | |
Financial Distress
I appreciate the reply! |
#9 | |
Not a lot of people run 19 inch wheels on these cars because: 1. They can be expensive 2. 19 inch tires can be expensive. 3. They are usually very heavy, negatively impacting acceleration, ride, and handling. 4. They require thin sidewall tires, negatively impacting ride. If done right, the impact on the way the car drives is reduced. But there is zero functional benefit to them. Everyone has different tastes visually and different priorities for their car. But a car with heavy 19 inch wheels will be less fun to drive. For me, that's the most important thing. I would highly recommend a quality 18x8 or 18x9 inch wheel with the right offset if you really want a larger size wheel. At the very least, do some extra reading before you spend a whole bunch of money on wheels. The link @monkeybike posted is very helpful. Staggering, or using a wider wheel at the back, isn't ideal for performance but not the end of the world. It does make rotating tires difficult. - Andrew <-----my 17x8 +40 offset wheels are being delivered tomorrow yayyyyy |
#10 |
17x8 +35 will be very close to flush, without compromising ride, handling, etc.
That said, if you want to stick with your original thoughts (10.5 rear, 9.5 front) you'll need coilovers (smaller diameter spring, more clearance up front before the wheel/tire hits the spring seat) and more camber to keep them under the fenders. Different diameters will look crappy IMO, and the extra weight and staggered will make the car a lot less fun to drive.
#11 |
A Nobody
Drives: FRS
i second the 17x8. i feel like for an NA car 8" wheels are plenty enough, get the proper offset (30-35) and with the right camber and a mild drop (.8-1") and youre golden in my opinion
#12 | |
Financial Distress
#13 | ||
Financial Distress
#14 | |
A Nobody
Drives: FRS
| Tags |
| brz, subaru, wheels |
| Can ya'll help me with some wheel recommendations? | Is Always Angry | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-30-2017 05:50 PM |
| Need alignment spec recommendations | 8RZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 05-10-2017 09:53 PM |
| Wheel Paint Recommendations? | flameSniper | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-28-2015 08:15 PM |
| Wheel recommendations? | cncnjn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-09-2013 06:30 PM |
| Wheel Directory: Subaru Legacy Spec B 18x7.0 +55 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-19-2012 05:52 PM |
