Old 11-06-2019, 12:54 AM   #15
Seoichi
Drives: 2016 Subaru BRZ Premium
So I am having second thoughts about selling my wheels. I have a set of ST coils at home, and was wondering what else I needed to fit the 18x9.5s with 245 tires? I know I need camber plates, but what are the reccomended specs?
Seoichi is offline   Reply With Quote
Old 11-06-2019, 03:21 PM   #16
Vital
Drives: 2015 BRZ
If you already have coilovers you are not going to have an problems. Just install the coilovers and fit your wheels and get rear lower control arms too dial in camber for rear.
Here is a thread to help you out.
http://www.ft86club.com/forums/showthread.php?t=60405
Old 11-06-2019, 05:51 PM   #17
carlovestela
Drives: 2015 Firestorm FRS
So 18x9.5+45 with 255/35/18 dont have rubbing issues with tein flex z/ bc coils?
Thanks
carlovestela is offline   Reply With Quote
Old 11-07-2019, 07:51 PM   #18
Vital
Drives: 2015 BRZ
Thanks
Yes, that is correct. The main issue with that size on stock suspension is the spring perches. With coilovers it eliminates those perches so you have more clearance. You should not have any issues just keep in mind that you may not able be able to run a lot of camber in the front depending on tire size.
Old 11-08-2019, 05:10 PM   #19
carlovestela
Yes. My set up now is -3 front -2.5 rear.
Now i have blox lca, im gonna do like stockish maybe -1.5 front -1 rear.
Old 11-08-2019, 05:40 PM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
"stockish" is 0 front. rather understeer-ish.
Wheel Spec Recommendations (Subaru BRZ) scottryan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 05-25-2018 04:56 PM
Personal wheel spec questions??? itsalexramos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 02-24-2018 08:12 PM
Torque spec for steering wheel nut? zooki Cosmetic Modification (Interior/Exterior/Lighting) 3 08-11-2015 02:14 PM
RB Wheel spec help Jrryjms07 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-14-2014 03:18 AM
Aggressive wheel spec info 2K13BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-31-2013 02:57 PM
