Drives: 2016 Subaru BRZ Premium
Wheel spec help
I purchased a set of WedsSport SA10Rs in 18x9.5 +45 used from a third party seller.
I'm on stock height and plan to stay that way for a while. I'm wondering on the fitment in the front? I've googled and read a lot, and some people say theres some rubbing, others are fine with coils etc. I plan to get 255s since this car is my daily and I've heard tires that are too stretched aren't good. Also, is it possible to full lock my wheels? I can run spacers but I dont know the recommended size. My cars suspension is currently fully stock. I've also heard I need new lug nuts, but I have no idea which ones to buy. Thanks in advance!! |
#2 | |
Drives: Looking to buy
Not sure if this information will help. There is also a thread here that tells what wheel setup their running and their fitment, you should look through there to see if they have your setup. Hope this helps! Sent from my GM1915 using Tapatalk |
Weight Weenie
Drives: 15 FR-S
| The Following User Says Thank You to new2subaru For This Useful Post: | soundman98 (11-02-2019) |
i tired that but i can't really tell if it'll fit on stock height. I was wondering if any other people with the same or similar setup can help me determine the best tire size, if the wheels can fit on stock suspension
Edit: nope, not once I put in the right data.
Point of note: the calculator is good, the idiot imputing the data wasn't. Another point of note: opps, hope they were cheap, what did they come off? What do they "really fit"?
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits Last edited by 86MLR; 11-02-2019 at 08:38 PM. Reason: Stupidity |
Drives: '23 BRZ
I think +40 as about the minimum offset to run 9" wheels, I can't imagine that 9.5" +45 would fit, I think you'll have interference with the strut.
Why not ask questions before buying wheels? |
Drives: Tornato grey 86
Honestly you're going not going to fit. You'll at lease need a 15mm spacer to clear stock suspension, coil overs at lease a 10mm.
You'll have a good amout of poke so some camber would be needed. Even then you'll run into the problem of destroying your fender when hitting bumps on the road. solution would be coilovers -4 camber if you want to run your 255 and your wheel combo with 10 mm spacer. Im not sure about full lock, but like ZDan said +40 is about the minimum off set for a 9 This is off the wheel calculator its honestly the best way to see fitment |
| The Following User Says Thank You to Grey86 For This Useful Post: | 86MLR (11-02-2019) |
#8 | |
Weight Weenie
Drives: 15 FR-S
OP sell them and get the proper size. Shit happens and you learned something from it. |
Hahaha yeah I found a few potential buyers from fb. Any size recommendations? I want 18s but it seems 17 is the best route for stock height:/
#10 | |
Weight Weenie
Drives: 15 FR-S
Yes, 205/55 R16 They're tons of fun! If i was to go 17" I'd use 17x9 +35 https://www.ft86club.com/forums/showthread.php?t=42746 |
#11 | |
Drives: '23 BRZ
If you want 18s that fit stock struts, stick with 18x8 or 18x8.5, with offsets in the +40 to +45 range, and run 225/40-18 size tires. Or you could run staggered wheels/tires with 225/40-18 fronts on 18x8 or 18x8.5 and 255/35-18 rears on 18x9 or 18x9.5 if you want. No reason to do that other than looks tho, what with 200hp and 55/45 weight distribution... Tire Rack has a decent selection that fit, gives a good idea of what you can run for widths/offsets front/rear anyway: https://www.tirerack.com/wheels/resu...odClar=Premium |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | new2subaru (11-03-2019), soundman98 (11-03-2019) |
#12 | |
Damn that's crazy...
Drives: 2015 BRZ
Also, I know there’s someone selling the same wheels you bought, but in 8.5 and think the offset is +45 so you can still get that wheel if you like that model. Really considered them and I’ve seem them at stock height with 225/40 and it looks pretty good |
#13 |
Drives: jrsc_brz
fwiw im on 18x8+45 225/40 stock susp. absolutely no problems there but thats not surprising.
i think u will fit your sa10r wheels, heres why: u will need 25mm spacers to retain the oe clearance from susp. components. that will make the wheels poke, but thats no problem bc you are not lowered. if your fenders were low asf, then you wouldnt want your tired directly under them, but youll have plenty clearance bc ur ride height is high, the only thing i see happening is slight fender rub at full turn in parking garages but who really cares abt that get muteki sr48 nug luts lol, theyre the industry standard. replace after 2-3 years if need be(winter driving etc), but dont get suckered into spending $250 on nug luts id get 235/40 tires for 9.5, but you can play it even safer and get 225 you see poke doesnt really matter if you have plenty ride height |
#14 |
Drives: 2013 Scion FRS white
The irony of this statement:
"id get 235/40 tires for 9.5, but you can play it even safer and get 225" that's stretched asf and nothing safe about it haha |
| The Following User Says Thank You to mrhayes1 For This Useful Post: | soundman98 (11-04-2019) |
| Wheel Spec Recommendations (Subaru BRZ) | scottryan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 05-25-2018 04:56 PM |
| Personal wheel spec questions??? | itsalexramos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-24-2018 08:12 PM |
| Torque spec for steering wheel nut? | zooki | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-11-2015 02:14 PM |
| RB Wheel spec help | Jrryjms07 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 07-14-2014 03:18 AM |
| Aggressive wheel spec info | 2K13BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-31-2013 02:57 PM |
