Old 02-21-2013, 04:28 AM   #1
zooki
Drives: waiting on a 2021...
Torque spec for steering wheel nut?
Does anyone have the torque specification for the nut that holds the steering wheel on?
zooki is offline   Reply With Quote
Old 08-11-2015, 01:56 PM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Diggging this thread because I'm doing this and it was bothering me not knowing the spec.
Looks like the manual says 29 ft/lbs
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-11-2015, 02:07 PM   #3
adamg
Drives: brz
interesting, pretty sure i did way more than 29 ft/lbs oops
adamg is offline   Reply With Quote
Old 08-11-2015, 02:14 PM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
I started cranking away on it, measured w the torque wrench and I was only at 21 ft/lbs, but I was already seeing metal shavings and I didnt want to go all the way to 29.
φφκα
Torque spec for lug nuts wrxneffect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 09-06-2016 08:39 PM
Camber bolt torque spec ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-09-2013 10:30 AM
Wheel Re-Torque to 89 ft-lb Brzce Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-22-2012 10:55 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
