#15 |
Benz Tech
Drives: 2017 BRZ Premium
Have you moved it at all after the repair? Our VSS codes won't clear from ESP. Replace the part, still have a current fault As soon as it rolls and couple hundred feet the lights all go out, code is stored and can be cleared.
Other than short or open circuit there is no way for the module to monitor a speed sensor at a standstill. Until it rolls and starts reading that fault can remain current. |
#16 | |
Benz Tech
With a more robust scanner you can read the actual ABS module and get the codes you actually need. That's why the engine code is so generic, it doesn't indicate any specific fault, just that there is a fault in the ABS system. Oddly enough, there is usually an OBD II partition even in the engine module. You cna have a code on a real scanner and nothing on a generic scanner, or a CEL on, no codes at all on the $40k+ scanner, $20 walmart scanner pulls it right up. Emissions is a funny game. |
#17 | |
Drives: Track preped NA FRS
#18 | |
Benz Tech
#19 |
Benz Tech
This is one I had yesterday. ABS/ESP lamps on, no CEL. No limp mode.
Current event in the transmission module, which could set a check engine lamp but did not in this case. Often you will have a code in the engine module for implausible CAN message received as well. The actual fault codes are in the ESP module. Without a real scanner you aren't getting this far. Some of our cars have 90+ control units. The vans are in the high 20s, low 30s. On this one, I replaced the LF wheel speed sensor. All lights still on, current faults. Lights were gone before I left the parking lot, codes were then stored and could be cleared. 5 different codes for a bad sensor, 4 with the exact same title. Silly Germans. Last edited by maslin; 04-16-2019 at 03:07 PM. |
#20 | |
I Love custom Turbo kits
Drives: Limited BRZ
When you say the light stays on you mean the CEL? Also, this google search has a bunch of other threads on the forum and some of them mention the ring was misaligned or warped causing the VSS malfunction. https://www.google.com/search?q=p050...hrome&ie=UTF-8
#21 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The orange cone sensor has reached 10 now.
That's the Thanks button just coming on.
"I gotta rock." -- Charley Brown |
#22 |
Thanks for all of the info guys, I have some more things to try before I throw the towel and just take it to the shop. @Sportsguy83 I think my code came on exactly because of the misalignment caused by the wheel hub moving about. I check the ring (you can actually see it with a flashlight thru the whole where the sensor is in), and rotating the whole thing around, there isnt a single scratch or change or anything that leads me to believe there is any damage. If there is damage, Im willing to bet its the cable, the connections or sensor. Will try some more things now that I have new ideas.
Thanks to everyone who chimed in, I really was out of ideas on this one. |
#23 |
Update for those insterested:
I took the car out around the block to see if the CEL would go away, it did not. So rolling on its own wheels didnt help. Either the problem is still there, or it needs to be cleared manually. I took the car to get an alignment at a friends garage the day after. He had the scanner that can actually read what the problem was. It was indeed the corner where I had the wheel hub back off (rear left). The fault was marked as current, but he was able to clear it with the scanner, CEL went off with it too. I cannot really drive the car on the street for it to complete its "checklist" after your reset any codes, but at least while moving the car in and out of the garage and into the trailer the code did not come back. I will buy a spare wheel speed sensor and just have it with me. If the codes comes back at the track at least I will know which wheel its in and I'll be able to swap the sensor on the spot. I wont be able to clear the code and I dont know if it will actually clear by itself if the problem isnt there, but he seems to agree with you that if the problem isnt there, the code should clear on its own by rolling. He was very surprised that resetting a "current" fault didnt bring it right back into limp mode with CEL on again, so a bit of a surprise there. |
| after resetting ecu | John27 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 04-22-2017 07:13 PM |
| Resetting ECU after cleaning MAF? | Hentai | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 12-15-2015 02:28 PM |
| Resetting the ECU after running 87 gas | orangespark | FR-S / BRZ vs.... | 10 | 08-29-2015 04:23 PM |
| iPod Keeps resetting, hanging; etc... Anyone else seeing this | Max1957 | Electronics | Audio | NAV | Infotainment | 5 | 03-17-2014 08:41 PM |
