#15 | |
Drives: BRZ 2018
I think I am the only one that uses toe out (1mm) front and parallel rear wheels for DD in our very slippery roads... |
| The Following User Says Thank You to JIM THEO For This Useful Post: | gpvecchi (11-23-2018) |
#16 |
Drives: Legacy GT
You might want to check your math on that one.
1/16 over 17" is more like 0.2º of toe. other thing is a cambered tire creates a thrust force in that direction so it may be a good idea to have a small amount of toe out with a lot of camber. If you have in the ballpark of 1.5-2 degrees of negative camber that would be an alright amount of tie. |
#17 |
Drives: BRZ 2018
https://robrobinette.com/ConvertToeInchesToDegrees.htm
If you set toe in inches 0.0625 (1/16) and tire diameter to 17" (24.6") then the result is 0.072...where am I wrong? |
#18 |
Drives: Legacy GT
Well, which is it?
And .07 is not 7 degrees- It's .07 degrees. Also 7' is not the right symbol for degrees assuming that is what you meant. With regard to angles that is the symbol for a "minute," which is 1/60th of a degree. To get a degree symbol (º) type alt+167 Last edited by jamal; 11-23-2018 at 05:33 PM. |
#19 |
Drives: BRZ 2018
I mean minutes not degrees as alignment machines read minutes or mm locally, but I am really confused now, how much is then 1/16" to minutes or mm?
#20 |
Drives: '23 BRZ
Units for alignment can be confusing...
' in this context is arc-minutes, not feet. 1 arc-minute = 1/60 = 0.0167° 1/16 inch toe-in at 17in. is (1/16")/17" = 0.0037 radians = 0.21° = 12.6' (arc-minutes) 1/16 in. toe-in at 25 in. is (1/16")/25" = 0.0025 radians = 0.14° = 8.6' (arc-minutes) Personally I wouldn't want more than 0.1° toe-in, and preferably closer to zero... |
#21 | |
Drives: BRZ 2018
#22 |
Drives: Legacy GT
I like to just use degrees and decimals at each corner, seems that's how most printouts I've see are. Then you don't have to worry about that whole how big is the wheel thing. And not that it makes much of a difference but the points you're measuring on a rim are going to be farther apart than the wheel size by like a whole inch.
Other thing I rarely see mentioned is the effect of camber thrust. Leaning a tire over creates a side force that wants to pull the tire in that direction. Some books indicate in the ballpark of the equivalent of 0.1 degree of toe per degree of camber. So, maybe it's a good idea to have a little toe out with a good amount of negative camber to make the tires roll straighter and reduce scrubbing and the tires both trying to turn in. On the other hand compliance in the suspension and steering might generate some toe out from tire drag. And also toe out will make scrubbing on the inside tire worse in a corner. Last edited by jamal; 11-24-2018 at 03:16 AM. |
#23 |
Drives: 2017 BRZ
And here I am worrying about hundredths of a degree while people can't even sort out how many degrees of toe they even have!
I currently have 0.02° toe out up front, 0.05° toe in rear... Basically zero... Small correction... An inch is ~25.4mm
| The Following User Says Thank You to cjd For This Useful Post: | wparsons (11-24-2018) |
#24 | |
Drives: BRZ 2018
By the way how many mm toe you have?
#25 |
Drives: 2014 GT86
Don't most dyno rigs allow selecting different measure units for toe, whichever seem more convenient? I don't get much all the fuss about converting.
#26 |
Drives: BRZ 2018
Alignment machines may be allow it, their operators don't know very often how to do it if you know what I mean...
#27 | |
Drives: 2017 BRZ
I don't figure you need to care about inches very often. lucky you. Just wanted to note in case government contractors building satellites decided to use your post as a reference...No idea how many mm toe I have, because it's a useless conversion for the way I do alignments. About that much. Might be 0.5mm toe in rear, 0.2mm toe out front (using the tire) if I didn't mess up the math. Which is interesting, because that means on this car each hundredth of a degree of toe might be just about one tenth of a millimeter of toe. I've been told my alignment setup has about 4x the resolution of the best laser alignment setups... It also can take 10x as long to do a proper alignment... partly because of cramped quarters in my garage...
#28 | |
Drives: BRZ 2018
| Alignment question. | ohnoitsthefuzz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-09-2015 08:33 AM |
| Alignment question? | cjsporl1996 | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 05:00 PM |
| brz alignment question | Shenks | BRZ First-Gen (2012+) — General Topics | 2 | 02-12-2014 10:23 PM |
| alignment question | hanabie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-15-2013 01:52 PM |
| Alignment question | retrosmiths | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-11-2013 11:44 PM |
