Old 02-08-2018, 06:22 AM   #1
bdtbdtbdt
Drives: 2015 Scion FRS
Alignment Toe Question
Should I measure toe from tire tread or wheel rim?
bdtbdtbdt is offline   Reply With Quote
Old 02-08-2018, 10:55 AM   #2
Racecomp Engineering
From the wheel. How are you doing the measuring?
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
wparsons (02-08-2018)
Old 02-08-2018, 12:18 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'm pretty sure the reported/standard measurement in units of length is at the tire tread, not the wheel.
25" tire OD, 1/8" (0.125") toe-in conversion to degrees = (0.125"/25")*180°/pi = 0.29°
If you measured at the wheel, 1/8" (0.125") toe would equate to (0.125"/17")*180°/pi = 0.42°, that's a big difference!
Old 02-08-2018, 01:06 PM   #4
jamal
jamal's Avatar
Drives: Legacy GT
What are you using? The rim provides a better place to measure with strings because the tire sidewall is not perfectly straight or parallel to the wheel surface so it is hard to measure precisely on 2 places on 4 tires. However, yes, that distance is shorter so it's a little harder to measure and adjust accurately. You could lean a rectangle of plywood against the tire like a toe plate and measure to the edges of that instead.
jamal is offline   Reply With Quote
Old 02-08-2018, 01:17 PM   #5
CoolHandMoss
Drives: 2013 FRS
Typically the wheel. The tire is too dynamic.
One good technique I've seen involves using a nail to just slightly score a center line on the tread of the tire as you spin it. Just enough mark to be visible. I suppose a good sharpie would work too. Then you measure to that line that you marked from a fixed point while the wheel turned. Still, the wheel is better.
ZDan's point about the difference of measurement is a good one but the spec is measured to the wheel as a standard. If you've ever watched a professional alignment, all the machines I've ever seen used are measuring to the wheel. Otherwise different tires, pressures, or even states of wear would be impacting alignment settings.
CoolHandMoss is offline   Reply With Quote
Old 02-08-2018, 01:29 PM   #6
It depends on the method. There are easy-ish methods to accommodate for either but it depends on how your doing your measuring. Many people that do at home alignments with toe plates measure at the tire but I would prefer not to do that.
There's at least 1 set of toe plates that are specifically designed to measure from the wheel, and if you're using strings it's not a big deal to use the wheel and IMO is preferable.
- Andrew
strat61caster (02-08-2018)
Old 02-08-2018, 02:14 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
The problem with using the wheel is that direct inches or millimeters of measured toe are not the same as the industry-standard which alignment specs are given in. You have to scale based on tire OD/wheel OD to get the conventional toe dimension.
0.125 inches of toe measured at the wheel on a 17" wheel with 25" tire = (25/17)*0.125" = 0.22 inches of toe in the standard measurement.
Again, it's a big difference and if you don't account for it you'll end up giving yourself way more toe than desired or intended...
Probably best to just convert directly to degrees which I prefer for units anyway, to remove ambiguity.
0.125" at 17" wheel = (.125/17)*180/pi = 0.42° (calculation for reference only, way too much for any usage IMO)
The Following 2 Users Say Thank You to ZDan For This Useful Post:
strat61caster (02-08-2018), wparsons (02-08-2018)
Old 02-09-2018, 06:49 AM   #8
bdtbdtbdt
I measured with string at the rim edges. Autox specific alignment. Not a daily driver. I set 1/8 " toe out front. 1/8 toe in rear. I've got tarmac2's. Is that an OK starting point Andrew? Thanks everyone for your help. GREAT forum!
Old 02-09-2018, 08:14 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Like I said above, 1/8" (0.125") *at the wheel* is 0.42°, IMO way too much for any usage. I prefer close to zero toe at both ends, but anyway I don't think you'd want more than 1/8" of front toe-out *at the tire*, which is 0.085" or a little less than 3/32" *at the wheel*, or 0.29°.
All that toe-in at the back of the car is, IMO, good for nothing and bad for everything, including turn-in responsiveness which I would think you'd want for autoX. I would run zero to no more than 1/16" rear toe-in *at the tire*, or 0.0425" *at the wheel*, about 1.5/32", or 0.14°
As the above numbers illustrate, you have to be able to measure distances more precisely at the wheel to make up for the fact that the measurements are only ~17" apart instead of ~25" at the tire tread...
bdtbdtbdt (02-10-2018), strat61caster (02-09-2018)
Old 02-09-2018, 10:51 AM   #10
IMO yeah that's too much toe. 0 up front or close to it at least as a starting point. 1/16 in at the rear as a starting point.
Converting to degrees is a good way to be sure you're doing it right.
- Andrew
Old 11-22-2018, 12:51 AM   #11
gpvecchi
gpvecchi's Avatar
So, when you're talking of 1/16, you're talking in inches, right?
gpvecchi is offline   Reply With Quote
Old 11-22-2018, 01:07 AM   #12
FirstWinter
Drives: Car
Yes, freedom units.
FirstWinter is offline   Reply With Quote
The Following 2 Users Say Thank You to FirstWinter For This Useful Post:
DarkPira7e (11-22-2018), gpvecchi (11-22-2018)
Old 11-22-2018, 07:08 AM   #13
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by FirstWinter View Post
Yes, freedom units.
Old 11-22-2018, 04:47 PM   #14
gpvecchi
gpvecchi's Avatar
I think here in Italy we measure toe at the rim edge, can you please tell me what 1/16 of inch is with 17" rims? I have total rear toe in of 1,6 mm... Thanks!
Alignment question. ohnoitsthefuzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-09-2015 07:33 AM
Alignment question? cjsporl1996 Tracking / Autocross / HPDE / Drifting 13 05-12-2014 04:00 PM
brz alignment question Shenks BRZ First-Gen (2012+) — General Topics 2 02-12-2014 09:23 PM
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 12:52 PM
Alignment question retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-11-2013 10:44 PM
