Old 11-23-2018, 02:11 AM   #15
JIM THEO
Drives: BRZ 2018
Originally Posted by gpvecchi View Post
I think here in Italy we measure toe at the rim edge, can you please tell me what 1/16 of inch is with 17" rims? I have total rear toe in of 1,6 mm... Thanks!
1/16 of inch is 25.2mm/16=1.575mm, when 1mm toe for 17" rims is about 7' this means 1/16 is 1.575x7'=11' toe!
I think I am the only one that uses toe out (1mm) front and parallel rear wheels for DD in our very slippery roads...
JIM THEO is offline   Reply With Quote
Old 11-23-2018, 01:22 PM   #16
jamal
jamal's Avatar
Drives: Legacy GT
You might want to check your math on that one.
1/16 over 17" is more like 0.2º of toe.
other thing is a cambered tire creates a thrust force in that direction so it may be a good idea to have a small amount of toe out with a lot of camber. If you have in the ballpark of 1.5-2 degrees of negative camber that would be an alright amount of tie.
jamal is offline   Reply With Quote
Old 11-23-2018, 04:08 PM   #17
JIM THEO
Drives: BRZ 2018
https://robrobinette.com/ConvertToeInchesToDegrees.htm
If you set toe in inches 0.0625 (1/16) and tire diameter to 17" (24.6") then the result is 0.072...where am I wrong?
Old 11-23-2018, 04:17 PM   #18
jamal
jamal's Avatar
Drives: Legacy GT
Well, which is it?
And .07 is not 7 degrees- It's .07 degrees.
Also 7' is not the right symbol for degrees assuming that is what you meant. With regard to angles that is the symbol for a "minute," which is 1/60th of a degree. To get a degree symbol (º) type alt+167
Old 11-23-2018, 04:47 PM   #19
JIM THEO
Drives: BRZ 2018
Originally Posted by jamal View Post
Well, which is it?
I mean minutes not degrees as alignment machines read minutes or mm locally, but I am really confused now, how much is then 1/16" to minutes or mm?
Old 11-23-2018, 04:47 PM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
Units for alignment can be confusing...
' in this context is arc-minutes, not feet.
1 arc-minute = 1/60 = 0.0167°
1/16 inch toe-in at 17in. is (1/16")/17" = 0.0037 radians = 0.21° = 12.6' (arc-minutes)
1/16 in. toe-in at 25 in. is (1/16")/25" = 0.0025 radians = 0.14° = 8.6' (arc-minutes)
Personally I wouldn't want more than 0.1° toe-in, and preferably closer to zero...
Old 11-23-2018, 05:06 PM   #21
JIM THEO
Drives: BRZ 2018
I run zero toe rear and 1mm toe out per wheel front with -1.4 degrees camber all around for DD but I believe a pyrometer is a "must" have for those that use their cars on track.
Old 11-23-2018, 07:30 PM   #22
jamal
jamal's Avatar
Drives: Legacy GT
I like to just use degrees and decimals at each corner, seems that's how most printouts I've see are. Then you don't have to worry about that whole how big is the wheel thing. And not that it makes much of a difference but the points you're measuring on a rim are going to be farther apart than the wheel size by like a whole inch.
Other thing I rarely see mentioned is the effect of camber thrust. Leaning a tire over creates a side force that wants to pull the tire in that direction. Some books indicate in the ballpark of the equivalent of 0.1 degree of toe per degree of camber. So, maybe it's a good idea to have a little toe out with a good amount of negative camber to make the tires roll straighter and reduce scrubbing and the tires both trying to turn in. On the other hand compliance in the suspension and steering might generate some toe out from tire drag. And also toe out will make scrubbing on the inside tire worse in a corner.
Old 11-23-2018, 11:02 PM   #23
cjd
cjd's Avatar
Drives: 2017 BRZ
And here I am worrying about hundredths of a degree while people can't even sort out how many degrees of toe they even have!
I currently have 0.02° toe out up front, 0.05° toe in rear... Basically zero...
Small correction... An inch is ~25.4mm
Old 11-24-2018, 02:39 AM   #24
JIM THEO
Drives: BRZ 2018
We live in different parts of the world, it doesn't mean people don't know how many degrees toe have but how to convert from one system to other, they have minutes or mm, so simple!
By the way how many mm toe you have?
Old 11-24-2018, 06:03 AM   #25
churchx
churchx's Avatar
Drives: 2014 GT86
Don't most dyno rigs allow selecting different measure units for toe, whichever seem more convenient? I don't get much all the fuss about converting.
Old 11-24-2018, 06:48 AM   #26
JIM THEO
Drives: BRZ 2018
Alignment machines may be allow it, their operators don't know very often how to do it if you know what I mean...
Old 11-24-2018, 12:07 PM   #27
cjd
cjd's Avatar
Drives: 2017 BRZ
I don't figure you need to care about inches very often. lucky you. Just wanted to note in case government contractors building satellites decided to use your post as a reference...
No idea how many mm toe I have, because it's a useless conversion for the way I do alignments. About that much. Might be 0.5mm toe in rear, 0.2mm toe out front (using the tire) if I didn't mess up the math. Which is interesting, because that means on this car each hundredth of a degree of toe might be just about one tenth of a millimeter of toe.
I've been told my alignment setup has about 4x the resolution of the best laser alignment setups... It also can take 10x as long to do a proper alignment... partly because of cramped quarters in my garage...
Old 11-24-2018, 12:49 PM   #28
JIM THEO
Drives: BRZ 2018
And here I am worrying about some minutes while people can't even sort out how many mm of toe they even have!
Alignment question. ohnoitsthefuzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-09-2015 07:33 AM
Alignment question? cjsporl1996 Tracking / Autocross / HPDE / Drifting 13 05-12-2014 04:00 PM
brz alignment question Shenks BRZ First-Gen (2012+) — General Topics 2 02-12-2014 09:23 PM
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 12:52 PM
Alignment question retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-11-2013 10:44 PM
