Old 09-30-2014, 11:37 PM   #239
ZZT86
ZZT86's Avatar
Drives: BR86
Originally Posted by Nicorutella View Post
So they said all the engine noise is the high pressure fuel pump which is total bs. It legit sounds like the engine rebuild went wrong and pistons are rubbing cylinder walls. I go to the dealer to see my car. I ran in the back to see what was going on before i talked to my service manager and i see this....
I did not tell the service rep that i saw this and i ask him so what are you doing to my car now? He says just replacing the high pressure fuel pump. So knowing what i saw i said are you sure thats it? He goes yes that is all. So anyone that knows this car will kno that you do not remove the engine to replace a high pressure fuel pump!
Was the dealer doing a dodgy on Toyota behind your back ? Or they're doing something without your knowing or consent ?
ZZT86 is offline   Reply With Quote
Old 09-30-2014, 11:43 PM   #240
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Id demand to know exactly what they're doing. There's no reason to remove the engine for a fuel pump. Looks and sounds like they're hiding something from you.
If they won't answer you, escalate to the regional office.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 10-01-2014, 12:05 PM   #241
ZionsWrath
Thanks
ZionsWrath's Avatar
I had this problem the first year I had my car.
This year I have been to a number of track events and have not had to add any coolant yet.
Old 10-01-2014, 03:33 PM   #242
aagun
Drives: 86
Question
Goodbye very well for coolent lost
aagun is offline   Reply With Quote
Old 10-02-2014, 09:50 AM   #243
Nicorutella
Drives: 2013 scion frs
I called new york regional office and corporate in cali... told them everything and the dealer called me immediately to apologize. They said that they replaced the fuel pump and it wasnt the prob. Obv was not the prob did you hear the noise you dumb a** so he says we ordered a second short block and are currently replacing it. My feeling is my car will never be the same again from all these engine tear downs. just waiting on the lemon law arbitration hearing. hope all goes well for me.
Nicorutella is offline   Reply With Quote
The Following User Says Thank You to Nicorutella For This Useful Post:
civicdrivr (10-03-2014)
Old 10-05-2014, 03:54 PM   #244
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Electrical Tape?
n8dog11914 is offline   Reply With Quote
Old 10-05-2014, 04:36 PM   #245
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Just buy a built block from Crawford performance and boost that shit!
texasbound972 is offline   Reply With Quote
Old 10-07-2014, 07:03 PM   #246
aagun
Drives: 86
Originally Posted by n8dog11914 View Post
Electrical Tape?
waterproof tape
Old 10-11-2014, 09:17 AM   #247
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Coolant Disappearing
I have a similar and am loosing sleep over it, please help. My reservoir coolant level keeps dropping. I last filled it, once engine was cold to the full mark october 5 and now its already half way between low and full. Only six days after and half of it in the reservoir is gone?? There are no leaks anywhere that i could see, the radiator is completely full, any ideas? I really dread the trips to the dealers as i honestly think they are the worse people to work on the car but i don't have a mechanic and the car's got 7k miles on it.
Man i swear i love these cars but god they have issues!!
For reference and future help to anyone with a similar problem. I took the car to the dealer and they did a pressure leak test. They found nothing, they say as long as the coolant in the reservoir doesn't go below the "low" mark, it's ok. If the coolant level drops below the low mark at any time then they'll have to perform other tests.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 10-11-2014, 07:00 PM   #248
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
My coolant kept dropping until eventually reaching the low line. I topped it off to full and since then it has never gone below the half mark. I also have the white spatter marks on some parts of my engine bay.
Old 10-13-2014, 08:57 PM   #249
Hanakuso
I have a feeling this solution will fix my issue. I've noticed the little black rubber hose is completely white/blue now.
Hanakuso is offline   Reply With Quote
Old 10-14-2014, 09:10 PM   #250
tebriel
Drives: 2004 WRX
Just as an aside, even though I don't have a brz/frs yet. I have had a number of subarus including 2 WRXs, and they all leak coolant lol. I have given up on keeping the leaks away so i just fill it up now and then. If you had HG probs the coolant is either going to go into the oil, or oil into the coolant, or you're going to smoke like a cancer patient.
tebriel is offline   Reply With Quote
Old 10-15-2014, 12:12 PM   #251
AznBRZer
Drives: 16 CBS WRX Limited
Originally Posted by AznBRZer View Post
Time for a bump and an update. I few months ago, my overflow tank was almost empty on a warm engine, so I had it filled up at the dealer. 4 months later and it's looking pretty level. Looks like it might've just been a bad burp in my case. Will update again.
Update to my update.
Checked my tank the other week and noticed that I'm losing coolant again. Not quite as bad as the first time, but it's a couple inches above low. What I should've done was mention it during my oil change so they'd fill it up again. I thought it was part of the "service." Guess not!
The only time it was filled after being purchased in April 2013, was in Nov 2013 and was below low. 11 months later, it's not below the line, so progress?
AznBRZer is offline   Reply With Quote
Old 10-15-2014, 01:17 PM   #252
yomny
yomny's Avatar
Well keep in mind that the tech at the dealer told me this fluctuation is normal and when cold it would be around the low mark, as long as it doesn't completely vanish from the reservoir bottle then we are good. I know this isn't normal to other cars but maybe it is to this guy b
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
