Old 04-13-2013, 05:08 PM   #1
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Engine Coolant?
I'm replacing the stock radiator hoses with hoses from Perrin. Needing to know what kind does of engine coolant the FR-S take?
Sent from my DROID BIONIC using Tapatalk 2
Chattanooga Scikotics MFIC
Red Robin Build
L3P47 is offline   Reply With Quote
Old 04-13-2013, 06:20 PM   #2
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
the blue kind that most subarus use
Jesse is offline   Reply With Quote
Old 04-13-2013, 06:49 PM   #3
L3P47
L3P47's Avatar
No the name of it?
Red Robin Build
Old 04-13-2013, 07:59 PM   #4
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
You have to pick it up at the dealer. They have a coolant and an additive at Subaru.
Ranatsu is offline   Reply With Quote
Old 04-13-2013, 11:33 PM   #5
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
If you go to Subaru to pick up the coolant it should be the "super coolant" and not the "long life" coolant. The coolant will be blue. also, make sure you let the system purge prior to finishing up on the job. Good luck!
alex_86 is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Green engine coolant used quickly? Tylub Issues | Warranty | Recalls / TSB 19 06-19-2013 01:15 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
