Old 03-14-2014, 02:13 PM   #225
AznBRZer
Drives: 16 CBS WRX Limited
Time for a bump and an update. I few months ago, my overflow tank was almost empty on a warm engine, so I had it filled up at the dealer. 4 months later and it's looking pretty level. Looks like it might've just been a bad burp in my case. Will update again.
AznBRZer is offline   Reply With Quote
The Following 2 Users Say Thank You to AznBRZer For This Useful Post:
86geek (03-23-2015), Lonewolf (03-14-2014)
Old 03-14-2014, 06:20 PM   #226
kodyo
Drives: Scion FR-S
I personally think the car "burns" a little coolant during normal use. I had to fill it up 3 months ago and it's already getting considerably below where I filled it up to last. Bought a jug of coolant and plan on just filling up as needed.
kodyo is offline   Reply With Quote
Old 03-15-2014, 08:15 PM   #227
Darkone
Darkone's Avatar
I know 2009 Cobalts had an issue called "porous block." Caused engine failure ...main symptom was losing coolant.
http://www.cobaltss.net/forums/08-10...thread-265567/
Also apparently Honda cars have this problem also..
Darkone is offline   Reply With Quote
Old 05-20-2014, 02:30 PM   #228
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by JDKane527 View Post
I have the Robispec radiator/oil cooler combo and noticed last night that my coolant after driving had been low when hot, just at the minimum mark. The coolant temps were normal, but the radiator fans were running at full, which made me think something was abnormal. I added some distilled water and we'll see how it goes.
Today was able to lift the car and noticed some coolant at the plastic access door on the passenger side underneath the car, so I'm hoping it's not a major leak. The drain plug has some residue so I'm going to try and remove the front bumper sometime this weekend or next to check out what could be the culprit. I have 19k miles, 5k miles since the radiator was installed.
Update:
Determined that the drain plug was the source of the leak. I was able to tighten it about 1 full turn. While the drain plug was loose, my coolant temps read over obd2 were 205-215F. After tightening the drain plug, temps were back at 190F, which was normal. Coolant wasn't exceeding the 1.3bar radiator cap since it was escaping out the drain.
My robispec cooler is losing coolant. Every time after I have driven around for a while I notice coolant on the bottom plastic panel underneath the radiator. I have to constantly fill up the radiator itself (the overfill bottle is always empty). I had sealed that drain plug with sealant (Amazing Goop thread sealant) so I don't think it is leaking from there?
Old 05-20-2014, 03:27 PM   #229
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Add some dye to the coolant to see if it is leaking elsewhere.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 09-15-2014, 02:43 PM   #230
Nicorutella
Drives: 2013 scion frs
Coolant and engine oil disappearing
I bought my scion frs march 2013 and ever since my 3-4k miles I noticed my engine going bone dry with no oil and also my coolant level very low. I brought it to toyota and they told me everything was normal. Now every 3-4k miles after that I kept having the same problem. Dangerously low oil levels. They continue to tell me this is normal which was total bs. 5 oil changes later them telling me this is normal I found traces of oil in my exhaust pipes and metal shards in it. I bring the car to them and they pull the engine to find that my cylinder walls have scoring on them from having no oil. They replaced my short block and gave me my car back. Now my car is making a winding noise when accelerating and when I come to a stop my engine is shaking as if it is about to fall out. I have been in contact with corporate toyota regarding this and they have helped some what but I have a service appointment tomorrow regarding this new engine shaking. Any idea on what I should request or if I should file a lemon law?
Nicorutella is offline   Reply With Quote
Old 09-15-2014, 03:07 PM   #231
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'd suggest looking up lemon law guidelines in NY and going that route. The car will never be the same to you imo. That's how I feel about mine.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-16-2014, 07:44 PM   #232
Nicorutella
I brought my car in for service today after only having the car back for 2 days and experiencing the engine shaking and making winding noise after they replaced the short block. Now they tell me not only was the engine a problem but they are replacing my transmission as well. I have contacted New york attorney general and also corporate toyota to see if they will settle before arbitration. If i dont hear back from toyota by weeks end i am sending NYSDRA the $250 necessary processing fee to get a hearing date.
Old 09-17-2014, 11:06 AM   #233
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I wish you best of luck. Keep us up to date.
Parting out HERE
Old 09-24-2014, 10:17 AM   #234
Nicorutella
My car is back in for service now for the 3rd time since engine and transmission were replaced. Check engine light is on with code p0353 which is ignition coil. Also my engine is making a winding noise and shaking and rattling. Sounds as if the rebuild was unsuccessful and sounds as if the pistons are rubbing the cylinder walls. something just does not sound right.
Old 09-24-2014, 10:39 AM   #235
Nicorutella
this is a video i took of the sound my engine is making
Old 09-24-2014, 09:15 PM   #236
Lonewolf
Lonewolf's Avatar
Drives: Moped
That does not sound reassuring at all...it could just be something that is loose/improperly fastened, but either way tell them to take it back and give you a loaner until you decide what you want to do (vehicle buyback, request new motor, etc)
Old 09-29-2014, 02:58 PM   #237
Nicorutella
So they said all the engine noise is the high pressure fuel pump which is total bs. It legit sounds like the engine rebuild went wrong and pistons are rubbing cylinder walls. I go to the dealer to see my car. I ran in the back to see what was going on before i talked to my service manager and i see this....
[ame]http://youtu.be/i3whl_Yb8RY[/ame]
I did not tell the service rep that i saw this and i ask him so what are you doing to my car now? He says just replacing the high pressure fuel pump. So knowing what i saw i said are you sure thats it? He goes yes that is all. So anyone that knows this car will kno that you do not remove the engine to replace a high pressure fuel pump!
Old 09-30-2014, 09:49 AM   #238
tomaszjanczak
Drives: Silver Subaru BRZ
I honestly hate going to the dealer so much, how can they all be so clueless? I wish independent shops could do warranty work, but the dealer would be out of business in a day probably. I have some engine problems too and my car has been at 2 dealers for 5 days total and they can't even diagnose the problem, which my car makes a knocking sound at start up. I was seriously thinking of just getting my car repaired professionally at a good local shop, but when a short block is involved or even worse, that is a good bit of money, so it's really a difficult situation.
Hopefully they know how to put the engine back in there! Idiots!
tomaszjanczak is offline   Reply With Quote
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 07:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-13-2013 11:33 PM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 08:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
