Old 06-04-2013, 01:23 PM   #15
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
The manual does have a sport mode which allows you a little less intervention from the nannies, I'd use it on canyon runs hence it does allow the tail to kick out, but would correct it if it's too much.
Old 06-04-2013, 01:30 PM   #16
Mikem53
Drives: FR-S 6MT
Originally Posted by Draco-REX View Post
Likely the torque converter was still locked, so the engine stalled because the wheels stopped spinning/went backwards. Not much you can do besides staying on the power or not spinning the car. With a manual you'd have the option of using the clutch to prevent the engine from stalling.
If your talking about the electronic torque converter lockup.. I thought that was only engaged in high gear.. Or are you referring to the stall speed of the tc ?
Mikem53 is offline   Reply With Quote
Old 06-04-2013, 01:34 PM   #17
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by LeeMaster View Post
In other words, switch to neutral when car spins out to prevent stall (but you wouldnt want to do that)
Yes, spinning your car badly can typically result in a stall - especially with an auto
Old 06-04-2013, 01:48 PM   #18
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I have generally experienced stalls in bad spins with several cars. I drive MT cars and usually am on the clutch and brake immediately. Still stalls. I think the sideways shock load on the engine does it, especially with stock engine mounts and suspension.
You should try and see if the "Pedal Dance" will work with an AT car. See this thread:
http://www.ft86club.com/forums/showthread.php?t=25494
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 06-04-2013, 01:49 PM   #19
Dezoris
Dezoris's Avatar
Check your PCV line from intake manifold down back of motor, this blew off/got loose and caused the exact issue for a few track guys.
Old 06-04-2013, 02:11 PM   #20
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Seems to be an Automatic trans issue and not an issue with the car. Try driving the car up a steep hill - while you are driving up the hill, come to a complete stop, and let the car roll backwards with your foot off the brake or gas - it will likely stall (make sure the hill is steep enough to allows the car to roll back - if the car doesn't have an anti roll back feature).
It's the nature of Automatic transmissions. Sorry.
GTM_Challenge is offline   Reply With Quote
Old 06-04-2013, 02:23 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Whichever. I just know that Autos stall out in spins much much easier than Manuals. It appears to be because the TC doesn't allow the engine to spin independent of the driveline in these situations.
Old 06-04-2013, 02:33 PM   #22
SkullWorks
Drives: SSM LT MT BRZ
the problem is you lifted.
Stay in the throttle, drive out.
Old 06-04-2013, 02:53 PM   #23
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by StormTrooper View Post
Pretty sure MT has sport and a separate traction control off.
From what I remember the auto has the same plus a useless snow button.
Could be wrong on the auto since I spent as little time as possible in the auto.
here's what i'm referring to - the MT has a 'VSC sport' button on the right side, which activates the VSC Sport mode:
The AT also has the VSC Sport button on the right side, but there's an additional Sport button in the middle as well (above the snow button) - it's not the same as VSC Sport. The Sport mode button in the middle just allows higher revs before gear changes - something that you'd do yourself on an MT.
shiumai is offline   Reply With Quote
Old 06-04-2013, 02:54 PM   #24
DR J
DR J's Avatar
Drives: Argento FRS
Did it happen one time or could you repeat it several times?
I was able to do it 4 times, after reading the posts I believe it was the going backwards at the end of the spin which makes sense.
DR J is offline   Reply With Quote
The Following User Says Thank You to DR J For This Useful Post:
Sportsguy83 (06-04-2013)
stall spin out drifting
DIY Cusco Spin Turn Knob Installation - Video Guide Alex DIY (Do-It-Yourself) Guides 25 08-02-2015 04:03 PM
FS: Cusco Spin Turn Knob Drift Button in Socal mtsui Interior Parts (Incl. Lighting) 4 06-09-2013 11:14 PM
Cusco Spin Turn Knob (Drift Knob) gatorbushmen Scion FR-S / Toyota 86 GT86 General Forum 8 04-30-2013 12:14 AM
AT holding 2nd gear to high revs during a long left turn EK_Golfer Scion FR-S / Toyota 86 GT86 General Forum 9 03-01-2013 11:35 AM
which spin turn knob fits the frs? gonzo Cosmetic Modification (Interior/Exterior/Lighting) 1 10-31-2012 08:12 PM
