Old 02-28-2013, 11:15 PM   #1
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
AT holding 2nd gear to high revs during a long left turn
Hey guys, I haven't seen this mentioned anywhere and I wanted to see if this was normal. With the car in lazy full auto mode (sport mode off), during a long left turn, the car will not shift out of second until after the car straightens out for a bit after the turn. I'm not mashing on the accelerator or anything and the engine will rev up to 4k+ rpm which is definitely high when not using sport mode. Could it be when the car senses the weight shift during a turn (limited slip differential kicking in) the AT will instinctively hold the current gear?
EK_Golfer is offline   Reply With Quote
Old 02-28-2013, 11:40 PM   #2
edward
edward's Avatar
Drives: 2013 BRZ - Sterling Silver Metallic
IIRC, It's a feature. Shifting mid-turn unsettles the chassis, which could result in a spin if you're driving at the limit, so the transmission tries to avoid this.
I could be wrong here, but I think I remember reading about this. I drive an MT, so I can't test this.
edward is offline   Reply With Quote
Old 02-28-2013, 11:42 PM   #3
fistpoint
Drives: Supercharged Golf Cart
That's exactly what I pictured in my head when reading his post. It makes sense.
fistpoint is offline   Reply With Quote
Old 03-01-2013, 12:04 AM   #4
EK_Golfer
EK_Golfer's Avatar
Yeah I was thinking this was the reason, but wasn't sure if the AT was programmed that way. Just making sure my tranny is going crazy on me.
Old 03-01-2013, 04:35 AM   #5
KayC
Drives: 2013 whiteout FRS 6mt
The car is telling you to power out and kick the tail out
KayC is offline   Reply With Quote
Old 03-01-2013, 07:35 AM   #6
trinitron
Drives: gts 86
I don't think it is an issue. Just tap the paddle shifter and upshift
trinitron is offline   Reply With Quote
Old 03-01-2013, 07:40 AM   #7
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Yes, normal behavior. Even in "lazy" mode it's more aggressive than your average autobox.
MVJ1975 is offline   Reply With Quote
Old 03-01-2013, 08:01 AM   #8
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
All FRS's are equipped with accelerometers that are tied into the ECU. This is how the VCS Sport function gets its attitude adjustment data to let you get a "little" sideways before the TCS and VCS kicks in.
Because of this, in an auto, the ECU may hold a shift for the same reasons stated above. Its even more exaggerated when the transmission is in "Sport" mode.
Scott
naikaidriver is offline   Reply With Quote
Old 03-01-2013, 08:20 AM   #9
Asphalt~86
Drives: Asphalt AT
Scott
This. When you put in Sport you will definitely notice the exaggeration of it holding the shift out. I found the spot now and it's easy to overcome if you just want a quick upshift with the paddles.
Asphalt~86 is offline   Reply With Quote
Old 03-01-2013, 10:35 AM   #10
EK_Golfer
EK_Golfer's Avatar
On my way to work, there is a large intersection with a huge left turn, I would love nothing more than to slide through that turn like a boss.
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
Anyone still holding out for BeSpoke? MrFRsLa Electronics | Audio | NAV | Infotainment 23 07-20-2012 04:24 AM
AC cuts out at high revs. Cool feature? Superhatch BRZ First-Gen (2012+) — General Topics 9 06-28-2012 02:13 PM
Moto Miwa: First batch of BRZ's and FRS left Japan for Long Beach, CA feedbag BRZ First-Gen (2012+) — General Topics 442 06-03-2012 02:54 PM
