Old 04-28-2013, 05:42 PM   #1
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Cusco Spin Turn Knob (Drift Knob)
Was thinking about buying a red Cusco Spin turn knob (only 25 bucks) in order to match the red accents throughout the interior of the car.
Only problem is that I don't know if the knob, when engaged in park, can be knocked out of place i.e. accidentally hitting it when leaving the car, thus allowing the car to move when parked.
I know the fail safe way would be to park the car in gear, but I'm just curious as to what exactly happens.....
When engaged, do you have to lift the ebrake, and then disengage it? Or do you have to simply push down on the ebrake itself to disengage?
gatorbushmen is offline   Reply With Quote
Old 04-28-2013, 05:52 PM   #2
THA STI GUY
DRIFT BUILD
THA STI GUY's Avatar
Drives: 2013 FRS
I just installed mine yesterday. all you do is pull up on the e brake and pull the knob out and it locks just like the original on. to disengage all you do is pull up a little and push the button back in. pretty much all your doing is removing the spring in the e brake and putting a longer button on so you can pull on it to lock it
THA STI GUY is offline   Reply With Quote
Old 04-28-2013, 08:25 PM   #3
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
^ this. It's mostly the same as a stock handbrake knob. Just pull the knob out as you pull up when you want it to stay locked.
Then press in like any other car when you want to disengage the handbrake
TylerLieberman is offline   Reply With Quote
Old 04-28-2013, 08:27 PM   #4
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Alright, thanks guys
Just ordered one for $29 shipped!
Old 04-28-2013, 08:36 PM   #5
cfusionpm
Drives: Firestorm 6MT Scion FR-S
I'd buy one just for kicks, but the video about it said it has some good rattle since it sits kind of loose in there. The only solution he gave was to "learn to live with it." I'll pass.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 04-28-2013, 08:40 PM   #6
TylerLieberman
Drives: '24 GR86
I never heard a rattle... Then again how could you over tire screeching, rev limiter and wind noise from being 80mph sideways?
Even if there was a slight rattle, the purpose it serves is well worth it
Old 04-28-2013, 11:25 PM   #7
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
I just installed mine. Chewed up the stock button when trying to twist it out though. But once installed mine never rattles. And there is no way it can become disengaged once the handbrake is up and the button locked. I tried to disengage it by hitting on the button but it never does. You have to pull up more and push the button back in to disengage
Check out my build: Instagram @kawallito
FutureFT86 is offline   Reply With Quote
Old 04-28-2013, 11:59 PM   #8
THA STI GUY
DRIFT BUILD
Drives: 2013 FRS
Ya i have not heard mine rattle yet either.
Old 04-29-2013, 11:14 PM   #9
Timtamtt
Timtamtt's Avatar
I'll just duct tape my button down when I need to hoon.
Timtamtt is offline   Reply With Quote
cusco, drift, knob
DIY Cusco Spin Turn Knob Installation - Video Guide Alex DIY (Do-It-Yourself) Guides 25 08-02-2015 03:03 PM
FS: Cusco Spin Turn Knob Drift Button in Socal mtsui Interior Parts (Incl. Lighting) 4 06-09-2013 10:14 PM
Question for the guys with the cusco spin knob "drift" knob Juurian Cosmetic Modification (Interior/Exterior/Lighting) 5 03-13-2013 08:51 PM
FS: Cusco shift knob Boost_Junkie Interior Parts (Incl. Lighting) 0 01-14-2013 09:23 PM
which spin turn knob fits the frs? gonzo Cosmetic Modification (Interior/Exterior/Lighting) 1 10-31-2012 07:12 PM
