Old 06-04-2013, 10:20 AM   #1
DR J
DR J's Avatar
Drives: Argento FRS
Stall in high G turn/oversteer spin
Last night I was doing some drifting in the rain in a parking lot and several times when I'd give it too much gas in the turn it'd oversteer and spin out and then stall. Started back up fine so I was thinking it was a sensor somewhere detecting something and shutting it down...
FRS Auto and I was driving with stability and trac off in sport mode.
Anyone had this happen to them or know if this is a safety feature or something???
DR J is offline   Reply With Quote
The Following User Says Thank You to DR J For This Useful Post:
Sportsguy83 (06-04-2013)
Old 06-04-2013, 10:35 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Did it happen one time or could you repeat it several times?
Old 06-04-2013, 10:35 AM   #3
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
not normal, but should be a good conversation with the dealer,......
microbionic is offline   Reply With Quote
The Following User Says Thank You to microbionic For This Useful Post:
Laika (06-04-2013)
Old 06-04-2013, 10:52 AM   #4
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Trac control off does not equal sport mode....
How much fuel is in the tank?
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 06-04-2013, 11:02 AM   #5
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
he's not equating the two; just describing the mode he was driving in. MT does not have a 'sport mode'; AT does.
shiumai is offline   Reply With Quote
Old 06-04-2013, 11:21 AM   #6
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
u essentially pit maneuvered urself (i did it in my old Accord once). cops hit the rear of ur car to spin u out b/c when it happens ur wheels backspin a bit and it causes the car to shut off to prevent damage from being in a forward gear while the wheels spin in reverse. nothing is wrong, cars are programed to do this
lbroskee is offline   Reply With Quote
The Following 2 Users Say Thank You to lbroskee For This Useful Post:
King Tut (06-04-2013), Sportsguy83 (06-04-2013)
Old 06-04-2013, 11:44 AM   #7
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
In other words, switch to neutral when car spins out to prevent stall (but you wouldnt want to do that)
LeeMaster is offline   Reply With Quote
Old 06-04-2013, 11:49 AM   #8
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
he was referring to tsc off and vsc sport on
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 06-04-2013, 11:51 AM   #9
xwd
To follow what others said about the wheels turning the wrong direction in gear, did you clutch in when you spun? I've spun plenty of times in autocross and as long as you remember to push the clutch in the car won't stall.
The Following User Says Thank You to xwd For This Useful Post:
CircuitJerk (06-04-2013)
Old 06-04-2013, 12:08 PM   #10
Sportsguy83
Drives: Limited BRZ
See above.
Old 06-04-2013, 12:31 PM   #11
markitect
Drives: Scion FRS
I think that is just how torque converters work, not really programming, but yes.
markitect is offline   Reply With Quote
Old 06-04-2013, 12:31 PM   #12
wheelhaus
wheelhaus's Avatar
Agreed with some of the responses above, but remember he's in an AT.
When an unrecoverable spin begins to happen in an MT, you must clutch-in when the car spins to prevent the tires from rotating backward while in a forward gear. You must hold the clutch in until stopped or at least facing the direction of travel.
However since you have an auto, I'm not sure what should happen here other than smacking the shifter to "N"... This is not going to be instinctive for auto drivers who aren't used to constantly fondling the shifter.
I think one of three things happened:
1- The ECU may have thought you were in an accident condition and shut off the fuel pump, but with as many poeple as we have trying to be king dorifto, I'd expect we'd hear about this happening more often.
2- You may have instinctively stepped on the brake when you spun out, which makes it extremely easy to lock up the wheels, and the engine died because it was still "in gear" and forced to stop rotating.
3- as you were spinning, the car will monentarily travel backwards, and a sudden reversal of wheel rotation may have forced the engine to stop.
Old 06-04-2013, 12:41 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Likely the torque converter was still locked, so the engine stalled because the wheels stopped spinning/went backwards. Not much you can do besides staying on the power or not spinning the car. With a manual you'd have the option of using the clutch to prevent the engine from stalling.
Old 06-04-2013, 12:59 PM   #14
StormTrooper
Pretty sure MT has sport and a separate traction control off.
From what I remember the auto has the same plus a useless snow button.
Could be wrong on the auto since I spent as little time as possible in the auto.
But like others have said if he spun that tightly it most likely caused the inside tire to spin backwards....
GR86 MT premium
stall spin out drifting
DIY Cusco Spin Turn Knob Installation - Video Guide Alex DIY (Do-It-Yourself) Guides 25 08-02-2015 04:03 PM
FS: Cusco Spin Turn Knob Drift Button in Socal mtsui Interior Parts (Incl. Lighting) 4 06-09-2013 11:14 PM
Cusco Spin Turn Knob (Drift Knob) gatorbushmen Scion FR-S / Toyota 86 GT86 General Forum 8 04-30-2013 12:14 AM
AT holding 2nd gear to high revs during a long left turn EK_Golfer Scion FR-S / Toyota 86 GT86 General Forum 9 03-01-2013 11:35 AM
which spin turn knob fits the frs? gonzo Cosmetic Modification (Interior/Exterior/Lighting) 1 10-31-2012 08:12 PM
