#29 |
Drives: BRZ D4S 6MT L Vortech
I am beefing that stuff up as I will eventually be going for more power (Visconti stg1+ or higher)
It was in my budget so I ordered it now |
#30 |
I've seen my oil temps climb pretty good during just normal operation. I plan to get out to the track more so this stuff makes sense to me. Would love to see if after you get it installed.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#31 |
Ordered an oil pressure sending kit to support the p3 air vent gauge. http://www.fastwrx.com/reoilprsekit.html
#32 | |
I Love custom Turbo kits
Drives: Limited BRZ
#33 |
| The Following User Says Thank You to v1ru5 For This Useful Post: | Sportsguy83 (06-04-2013) |
#34 |
@Sportsguy83 the P3 air vent gauge supports a fuel pressure sensor also, what is needed to hook that up?
#35 | |
Drives: Limited BRZ
#36 | |
OIL PRESSURE 150PSI $60 FUEL PRESSURE 150PSI $60 <-- did I just waste $60? is fa20club ripping people off? https://docs.google.com/a/troy.sh/fo...6yKWk/viewform |
#37 | |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
![]() Quote:
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
| The Following User Says Thank You to Adeets For This Useful Post: | TouchMyHonda (08-05-2013) |
#38 | ||
Drives: Limited BRZ
Edit: installing the Fuel pressure sensor will be a bit more involved as most probably you will need to buy the special tool required to work with the fuel lines. Quote:
#39 | |
#40 |
Drives: Limited BRZ
I think its personal preference at this point. I got an external reading for AFR because I wanted to have independent verification of the reading the OBDII OEM sensor can provide, and because the other O2 reads a wider band. You will be fine with the stock sensor and OBDII reading. Think of the other sensor as not required but nice to have..
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | v1ru5 (06-04-2013) |
#42 | |
I plan on going stg1+ in the future. What sensor should I buy, and where do I install it? The fa20club p3 air vent gauge I bought supports a 5v input for fuel. |
| FR-S | driver01 | Forced Induction | 78 | 07-04-2013 10:07 PM |
| Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned | congiiee | Forced Induction | 131 | 05-30-2013 12:28 AM |
| FA20Club tuned Vortech kit 93 octane | draggin_az | Forced Induction | 58 | 05-29-2013 03:45 PM |
| Visconti Tuned 0-60 | brichard0625 | Engine, Exhaust, Transmission | 96 | 09-16-2012 09:56 PM |
| Another Accelerated Performance Turbo BRZ - Visconti Tuned ! | Visconti | Forced Induction | 34 | 08-28-2012 12:47 AM |
