Old 04-07-2013, 11:36 AM   #1
congiiee
Drives: WRB Subaru BRZ
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned
Intro:
As the title says I just installed the Vortech Supercharger kit (upgraded version). I purchased the STG1+ kit from Visconti who was very helpful and responsive through the whole process of purchasing the kit and waiting for it to come. Although it took 45 days for it to come, I did get the upgraded version of the kit and did not have to ship it back and forth to do that. This was probably the longest and most unbearable wait I'd ever experienced xD
Car before Vortech:
Alright this is embarrassing but my car was BONE STOCK with only Visconti's pump fuel tune as a performance upgrade. I didn't even upgrade my wheels nor tires yet. Because of my tires my first impressions section underneath would be with the fact that traction control was on... I will get my new wheels and tires mounted hopefully the end of this month of the next and will be more aggressive when that times comes to test out the kit.
Installation:
Originally I set out to try to taking a lot of pictures didn't get to it as I was trying to figure out how to install it as I went. It did take me two days and around 12 hours to install total. Note I am 20 years old and know nothing about cars until I bought my BRZ. If I were to do it again I could probably get it installed in around 8 hours with the proper tools. The hardest part in my opinion of the installation would have to be getting the mounting bracket for the intercooler installed. I had a terrible drill . Having another person helping you is a must in my opinion. Taking the bumper off was also pretty annoying as I didn't really know how rough I could be with it to take it off. Overall I managed to install it and that SAYS a lot! If I could do it anyone could install this kit and save themselves a few hundreds dollars of installation.
After everything was on, things to make check over was if the belt was properly seated to the pulleys, hoses were all on and out of the way of moving/hot objects and CHECK/TIGHTEN ALL CLAMPS!!
The kit I purchased also came with the smaller pulley from Vortech and Injectors/fuel pumps from Visconti which I did not install. I figured its better to add a little bit of power at a time and see how it goes. I don't wanna risk putting to much stress on my car just yet. Once I need more power I will install the smaller pulley and get E85!
First Impressions:
Immediately after the installation, I got my laptop and tuned the car with the Ecutek Prokit from Visconti and his STG1 tune. That was probably the easiest part of the installation . Once that was done my heart was pounding like crazy. I was half worried/anxious that I might have not done something correctly. A took a deep breath and pressed that button (BRZ Limited). The car.....STARTED! I have never felt more accomplished. I will also post the video of the first start up. I waited a bit for the tune to do its thing then took the car out for a spin. HOLY F$*%! I was easily able to feel the boost kicking in starting from 2k to 3k rpm (DD speeds). The car moved much more easily around these rpm ranges. After 3k you really feel the boost kick in and at 5k+, you're in for a roller costar ride. With the added speed I can say the car still maintain its characteristics.....but on STEROIDS! With that I haven't even pushed my car past 7k and I believe with John's tune it goes a little past 8k rpm or at least has the ability once he fine tunes it more. On the second day I actually got into some races on the highway (DONT DO THIS AT HOME BTW lol). It was actually coincidental I happened to run into 4 people racing down 66 (major highway in Northern VA). I downshifted to 3rd gear and challenged a WRX which I believe was an STI. The first round...I got smoked as I did not know what I was doing. The second time I pushed passed him so fast he just stopped. Then the third was the most fair and when we started, I easily pulled ahead of him. The speeds that were at was around 55-100 mph. I also got to race a heavily modified Chevy Cobalt or at least I think it was. It was past 11pm and I couldn't really identify the car. The first time I had a bad start but starting gaining on him. Then the second time.....I will post this tragic experience on the issues sections... Overall I love how my car is now!!! I honestly would be content and happy with this as it is without adding the pulley or E85 down the road. Even so I feel like some more boost is very manageable and drivable in this car with the right upgrades to complement more boost.
Problems/Issues:
Unfortunately I did run into a few issues. Luckily they were minor errors. The first one would be the wash fluid reservoir. I did everything correctly but it seems to leak. I tried to use tape sealant but it still had a slight leak so I decided to give up for now and drain the fluid. I just wanted to drive my car. The next issue would be involving racing the Chevy Cobalt. I was in third gear and at around 60mph. Floored the pedal and at 7k rpm heard a rush of air escaping and lost my acceleration. I immediately knew something felt weird. Driving home I could feel the car not being as powerful and as if air was escaping somewhere. Originally I thought it was my blow off valve leaking. After taking the car home and inspecting it I could see that the pipe connecting the pipe coming from the supercharger was loose. It was 1/4 off. I suspected I had forgotten to tighten the clamp. Had to take out the bumper again but fixed the issue. I am with BOOST again
Future Plan:
NOTHING!...................jk
heres a list:
-wheels/tires
-lowering springs,
-spyder taillights
-carbon fiber interior
-perrin catback exhaust resonated
-perrin front pipe catted
-perrin overpipe
-nameless header catted
-light weight pulleys
--thats it for now that I can think of. If you have any suggestions post them!
PHOTOS/VIDEOS/DATA:
My car ride:
http://www.ft86club.com/forums/attac...1&d=1365397524
It came!!
http://www.ft86club.com/forums/attac...1&d=1365397726
took off bumper and intake
http://www.ft86club.com/forums/attac...1&d=1365397318
installed
Intercooler
yes that goofy asian kid is me lol
https://www.dropbox.com/s/ns29vrc5pa7pra7/IMG_0919.MOV
I will post pictures, videos, and dyno sheets once I get them. If anyone wants to see anything or have questions just request it in a post. THANKS!
congiiee is offline   Reply With Quote
Old 04-07-2013, 11:37 AM   #2
congiiee
RESERVED for.....I don't even know what lol just in case
Old 04-07-2013, 11:42 AM   #3
2forme
Get that kit dynoed!!!
Old 04-07-2013, 11:45 AM   #4
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
there you are..
yes, I'm in for results too
Huehuecoyotl is offline   Reply With Quote
Old 04-07-2013, 11:49 AM   #5
mashal
DADA
mashal's Avatar
Drives: 2013
So right now your car is bone stock + supercharger ?
mashal is offline   Reply With Quote
Old 04-07-2013, 11:51 AM   #6
congiiee
uh huh...lol. I will try to get my car dynoed ASAP. I need to also do some data logging and getting it fine tuned before I dyno.
Old 04-07-2013, 12:06 PM   #7
mashal
DADA
mashal's Avatar
Drives: 2013
I was just curious to how the tires handled the extra Hp?
Old 04-07-2013, 12:11 PM   #8
2forme
You'll be our first bone stock vortech sc car.
Old 04-07-2013, 12:28 PM   #9
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
DEFINITELY want to see a dyno of this with John's tune and NOTHING else.
What kind of gas is available where you are? Are you on 93?
Wish we could have gotten a baseline dyno but still interested in seeing what you get.
Chewie4299 is offline   Reply With Quote
Old 04-07-2013, 12:29 PM   #10
Chewie4299
Spaceman
Chewie4299's Avatar
Also, street racing is bad. Mmmkay?
Old 04-07-2013, 12:31 PM   #11
2forme
We will say he wasn't street racing. He was aggressively passing.
Old 04-07-2013, 01:03 PM   #12
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
And it just so happens that person was trying to pass him at the same time. What are the odds. Lol.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 04-07-2013, 01:08 PM   #13
Calum
That Guy
Drives: 2013 asphalt FRS MT
Another one in for results!!
Old 04-07-2013, 01:11 PM   #14
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Or we could say he was street racing. Take vids next time, I wanna see a frs actually win a street race for once.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
*PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) PhastekSport Forced Induction 425 04-26-2013 10:06 AM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Vortech Supercharger Tuner Kit With Visconti Tuning Calibration @Pure Automotive Pure Automotive Forced Induction 33 03-31-2013 09:22 PM
Vortech Supercharger Tuner Kit With Visconti Tuning Calibration @Pure Automotive Pure Automotive Engine, Exhaust, Bolt-Ons 60 03-31-2013 09:21 PM
Finally got my Celica supercharger installed and tuned clayrush Other Vehicles & General Automotive Discussions 7 09-07-2012 11:26 PM
