Old 06-04-2013, 08:07 AM   #29
v1ru5
Drives: BRZ D4S 6MT L Vortech
I am beefing that stuff up as I will eventually be going for more power (Visconti stg1+ or higher)
It was in my budget so I ordered it now
v1ru5 is offline   Reply With Quote
Old 06-04-2013, 08:23 AM   #30
swift996
swift996's Avatar
I've seen my oil temps climb pretty good during just normal operation. I plan to get out to the track more so this stuff makes sense to me. Would love to see if after you get it installed.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-04-2013, 10:04 AM   #31
v1ru5
Ordered an oil pressure sending kit to support the p3 air vent gauge. http://www.fastwrx.com/reoilprsekit.html
Old 06-04-2013, 10:08 AM   #32
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You sure you will need all that? The sender fits where I show on my pic.
Old 06-04-2013, 10:19 AM   #33
v1ru5
idk if i need it or not, it's $20 more. I can use it without the extension hose if it fits fine.
The Following User Says Thank You to v1ru5 For This Useful Post:
Sportsguy83 (06-04-2013)
Old 06-04-2013, 10:28 AM   #34
v1ru5
@Sportsguy83 the P3 air vent gauge supports a fuel pressure sensor also, what is needed to hook that up?
Old 06-04-2013, 10:32 AM   #35
Sportsguy83
Drives: Limited BRZ
You can get that through OBDII, so its probably going to show without needing an external sensor. @FA20Club.com can correct me if wrong
Old 06-04-2013, 10:36 AM   #36
v1ru5
EXTERNAL SENSORS
OIL PRESSURE 150PSI $60
FUEL PRESSURE 150PSI $60 <-- did I just waste $60? is fa20club ripping people off?
https://docs.google.com/a/troy.sh/fo...6yKWk/viewform
Old 06-04-2013, 10:37 AM   #37
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
You can get that through OBDII, so its probably going to come off without needing an external sensor. @FA20Club.com can correct me if wrong
During my tune my AFR reading around 6600 always kinda went wacko, so I'm also getting an external AFR gauge for drive around, if there's an issue with the stock AFR gauge, reading from that gauge is going to be pointless, that's why I'm going for both, Torque app for cars AFR, and external for real AFR.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following User Says Thank You to Adeets For This Useful Post:
TouchMyHonda (08-05-2013)
Old 06-04-2013, 10:41 AM   #38
Sportsguy83
Drives: Limited BRZ
EXTERNAL SENSORS
Well, OBDII will tell you the DI pressure, BUT I think it will not tell you the pressure in the fuel line and that is probably the sensor Tony is selling. I didn't mean to provide false info so, sorry for that.
Edit: installing the Fuel pressure sensor will be a bit more involved as most probably you will need to buy the special tool required to work with the fuel lines.
We are talking about Fuel pressure, not Air/Fuel ratio. I personally have a third O2 sensor and AFR via Failsafe guage. I like the wideband readings.
Old 06-04-2013, 10:42 AM   #39
v1ru5
Thanks. I honestly have no idea what i'm doing with gauges and sensors. What is an afr sensor? Should I be worried about getting one?
Old 06-04-2013, 10:45 AM   #40
Sportsguy83
Drives: Limited BRZ
I think its personal preference at this point. I got an external reading for AFR because I wanted to have independent verification of the reading the OBDII OEM sensor can provide, and because the other O2 reads a wider band. You will be fine with the stock sensor and OBDII reading. Think of the other sensor as not required but nice to have..
The Following User Says Thank You to Sportsguy83 For This Useful Post:
v1ru5 (06-04-2013)
Old 06-05-2013, 09:15 AM   #41
Visconti
Drives: 05 STi
You can't trust the oem sensor. It's good for a reference only.
It's suggested guys with fuel systems get a wideband AF sensor
John
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
v1ru5 (06-05-2013)
Old 06-05-2013, 09:22 AM   #42
v1ru5
John
Thanks John,
I plan on going stg1+ in the future.
What sensor should I buy, and where do I install it? The fa20club p3 air vent gauge I bought supports a 5v input for fuel.
FR-S driver01 Forced Induction 78 07-04-2013 10:07 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
FA20Club tuned Vortech kit 93 octane draggin_az Forced Induction 58 05-29-2013 03:45 PM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
