#15 | |
and are you saying the dw65c is not as good as the Visconti ??
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#16 | |
I Love custom Turbo kits
Drives: Limited BRZ
That DIY (supposedly for the Visconti pump), instructed you to not use the white spacer, only two O rings and the car did not even start because it was not holding pressure. I call someone and ask, and he says I probably inverted the cables (Visconti pump you need to solder the pum cables to the OEM connector). Took it out, installed second time, now the cables where really inverted so it didn't work. Third time, I inverted the cables and was told to use the white spacer and two O rings. This time the car started and worked fine. I was wary on using zip ties to hold the canister together, so I took the plunge and bought the DW65c pump. Installed per the DW65c included instructions (two O rings, no white spacer). Worked fine for about two weeks, started getting fuel starvation at high RPMs on third. I took it out one last time... , so I installed 4 O rings and NOW finally my FP holds pressure all the way through any gear. The thing is that if the FP is not SUPER tight inside the canister, you start loosing fuel pressure through the sides of the O rings.What I meant between the DW and Visconti pump is, the Visconti pump is made by Speed by Design and they have a good reputation and it also flows a bit more LPH at 290. DW don't have the best reputation in the industry (although most bad reviews are for injectors, not FP), and it flows a bit less at 265 LPH. Still 265 is good enough for 400 WHP and more.
#17 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
^ good info, you dirty thread jackers. Hahaha
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
#18 |
Drives: Limited BRZ
LOLOLOL agree, my bad! @charged86 We can take the convo to that thread I linked!
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Wonderbar (06-02-2013) |
#19 |
NASA SpecE30 Racer
What series do you plan to race this racecar in?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#20 | |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
With stock injectors and fuel pump, with stock vortech pully, my tune is at the very edge of the injectors cycle time. So with stock everything if you get a proper tune, yes you will need fuel pump and injectors to make above 263whp with the stock vortech. But since wonder is flat lining like the perrin triplets, and charged86 is using visconti I'm guessing neither of you are at that point. Edit: sorry wonder didn't notice the tag said you were perrin tuned, so perrin quadruplets? @charged86 at least it's not your fuel system boning you right!
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
| The Following User Says Thank You to Adeets For This Useful Post: | charged86 (06-04-2013) |
#21 |
Driveway labs.
This is an in-betweener for me, I autox it and want to hit some road course with it until my Mitsubishi is finished at PSI. Then the eclipse is the racecar and this is a tuner/DD
| Vortech Visconti Tuned on BRZ Limited | v1ru5 | Member's Car Journals | 85 | 01-08-2015 01:09 PM |
| Vortech Visconti tuned on ft86me | ft86me | Forced Induction | 38 | 08-25-2013 09:00 PM |
| FA20Club tuned Vortech kit 93 octane | draggin_az | Forced Induction | 58 | 05-29-2013 03:45 PM |
| Vortech charged BRZ, Perrin tuned. | Wonderbar | Forced Induction | 20 | 05-28-2013 12:31 PM |
| *PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) | PhastekSport | Forced Induction | 425 | 04-26-2013 10:06 AM |
