Old 05-28-2013, 11:34 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
Vortech Visconti tuned on ft86me
I am no longer with visconti and now with FA20CLUB. Any questions feel free to PM me. thanks!!
Alright, so here is my experience with the vortech build. Again, i'm not the best at this so this is my attempt to discuss what I like and dislike about everything. No bias what so ever, just my own personal opinion.
The package:
Everything was in the box as was supposed to be. Everything was packaged very well and very well protected. Everything was very organized and the instructions (cd) are VERY detailed. There are even pictures that can be enlarged to provide instructions with where to drill and grind down etc.
Install:
The install did take the whole day with an hour lunch. So give the start time of around 9am and lunch from 12 to 1pm, the install was finished around 7-8pm. If you are doing the install, I highly recommend taking a look at the instructions before hand so you know what you're getting into. Modifications are necessary, but nothing major. If anything the modifications such as the washer fluid made my life easier with my perrin oil cooler since the lines have more space to move.
Overall, great instructions, modifications needed, not difficult yet time consuming.
The aftermath:
Well after flashing the rom file provided by Visconti and letting the car run for about 15 minutes, it was time to take the car for a little drive after warming everything up and rechecking fluid levels in things such as the coolant, oil, and sc oil. No issues with start up and everything ran perfect. I also have to mention that the kit looks VERY subtle from up front. As you can see from one of my pics up front, the intercooler isn't really visible and if you have the perrin oil cooler as I do, you definitely can't notice the intercooler and your attention is drawn to that dinky little oil cooler haha. Personally, I was going for the OE look since cops around here in the oc/ie can be well, not nice haha. Also in the engine bay, the kit looks good in all black. No shiny chrome stuff. It looks very low key and clean.
Took it out and gave it a little drive and definitely there is a big difference between stock and being boosted. The engine doesn't give you a 4k ass kickin like a turbo does when boost kicks in, but the engine feels like a bigger engine...a rather bigger engine. That was what I was def aiming for. Took it up to about 6k and let the gas off and WHOOSH. Man was I stoked haha. Power is very immediate with this kit and throughout the power band, the power continues until red. You will find yourself being pulled back some in your seat while flooring it. I didn't feel a torque dip and the power distribution is absolutely smooth all the way to red and honestly, the power difference is a little scary at first haha. Visconti did a great job with the tune file. There weren't any issues with things such as knocking or power loss anywhere. Like a turbo you will hear the spool and the bypass valve will whoosh when you let off. I was very surprised to feel the amount of torque that came from the kit along with the amount the rpms would rise. I found myself running through gears MUCH MUCH MUCH quicker than stock and let's just say, it will have you smiling from ear to ear.
pros:
super discrete look when looking from the front
OEM look
not hardcore of an install
rpm jump up rather quickly
improved throttle repsonse
immediate power gains
huge difference over stock
power throughout the power band
spool sounds mean along with the bypass when let off
torque dip not present
feels like a big motor vs the turbo kick at boost
lag is absolutely minimal
makes the frs feel like a car that has the proper amount of power as well as handling capabilities
[B]cons:
nothing wrong with the kit itself as of 08.25.13 no belts rubbing or pulleys coming loose. everything is still great!
issue with popping noise was present with previous tune on visconti which seemed like the DI problem, but with fa20club, there is no popping and the tune from fa20club is BEAST! night and day difference.
Current mods:
Visconti Vortech STG 1 kit VISCONTI TUNED now fa20club
Perrin oil cooler
Koyorad upgraded radiator
stock injectors
stock clutch
ark catback 2.5"
ark test pipe 2.5"
KW v3
whiteline camber bolts up front
work emotion 18x8.5, 18x9.5
cusco front strut tower bar
cusco rear strut tower bar
cusco front lower arm
cusco powerbrace front member
cusco powerbrace rear member side
cusco powerbrace rear end
cusco brake cylinder stopper
cusco front sway bar
cusco rear sway bar
cusco rear pillowball lateral link
cusco engine powerbrace (in box going on in a week)
cusco oil filter
6000k hid
yellow drl
nitto nt05 245
beatsonic sharkfin
led package
seibon carbon rear seat delete
t1r mirrors
trd spoiler
crystal eye led tail lights
LED package
upcoming mods in box and ready to install:
sparco wheel
nrg quick release
bell hub
vortex lip kit
greddy carbon hood prop
goodridge brake lines
winmax brake pads
motul brake fluid
that's that! follow me on IG =>> Whoaitsallen
ft86me is offline   Reply With Quote
Old 05-29-2013, 01:28 AM   #2
Sniper2606
Sniper2606's Avatar
Where the heck is the vortech intercooler at?
"the kit took about a couple weeks for delivery. I wasn't expecting it to come that fast with how busy Vortech has been lately, but hey, I'm happy"
You my friend must be the luckiest person ever, maybe its because you live in CA close to Vortech
Still waiting here for my kit that i order long ago
Regardless, car looks good
Sniper2606 is offline   Reply With Quote
Old 05-29-2013, 02:59 AM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
3rd pick down behind the oil cooler haha. see what i mean? low key!!
haha idk man but i just fee lucky for sure!! you'll get it. where did you order it from?
thanks man!!
Old 05-29-2013, 03:12 AM   #4
Sniper2606
Sniper2606's Avatar
Originally Posted by ft86me View Post
thanks man!!
Order mine on the 5th of may.
You must have some serious connections to get yours earlier than me
Old 05-29-2013, 03:35 AM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
not at all. vortech is the company that will supply you the kit. rich and john will take your order and submit it. the rest is in the hands of vortech. rich and john have been pushing them to get things going faster, but vortech is currently backed up with all of the other orders as well replacement of older blowers. i'm not sure how i got mine in the time frame that I did, but i consider myself lucky. i just waited. that's all.
Old 05-29-2013, 03:44 AM   #6
Sniper2606
Sniper2606's Avatar
Yup this is all true, John sent me the ECUtek kit pretty quick.
I already called Vortech but no luck trying to get an update all they tell me is to contact John, but i dont wanna bother him.
Im all about waiting in line as well, but this doesn't seem correct IMO
Like i said before its either because you live in CA or my order is just floating out there around the vortech office. Kinda crazy you order on the 13th and got it first, play the lottery my friend lol :happy0180:
Sorry for whoreing your thread ft86me.
Maybe @Brian@Vortech wants to chime in
Brian@Vortech
Old 05-29-2013, 07:47 AM   #7
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Is the pipe to the TB smaller than the TB? Looks like there could be a better seal there.
SloS14 is offline   Reply With Quote
Old 05-29-2013, 08:20 AM   #8
retrosmiths
Drives: Scion FR-S Whiteout
Is the installation doable at home without using a lift?
Sent from my Galaxy Nexus using Tapatalk 2
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 05-29-2013, 10:51 AM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
sparco wheel
nrg quick release
bell hub
Oh noes. I see another steering wheel in the hand Instagram photo coming up.
Old 05-29-2013, 10:51 AM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yes. There is no job that is not doable at home without a lift.
Old 05-29-2013, 11:03 AM   #11
Foobar
SLO NO MO
Foobar's Avatar
A lift will save your lower back, but I did mine with ramps. You could do it with jackstands.
Old 05-29-2013, 12:14 PM   #12
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Just a suggestion, but you might want to find another spot to mount the oil cooler. By placing it in front of the intercooler, you are only going to succeed in compromising the effectiveness of both units. I know the instructions on the Perrin oil cooler say to mount it in that spot, but they probably weren't thinking in terms of an intercooler being mounted directly behind it when they wrote those instructions.
Brian@Vortech is offline   Reply With Quote
Old 05-29-2013, 12:31 PM   #13
dabocx
dabocx's Avatar
Drives: Scion FRS
Maybe with some longer lines you could put it behind where the fog lights would go like Full blown did?
dabocx is offline   Reply With Quote
Old 05-29-2013, 12:44 PM   #14
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
All of our testing/proving has been done with the oil cooler in that position.
While this can increase the charge temperatures some amount, it's not enough to worry about.
During our dynoing, (less air flow than what we see on the road) our charge temperatures only got up to about 100F during some 13PSI runs.
PERRIN_Mladen is offline   Reply With Quote
Vortech Visconti Tuned on BRZ Limited v1ru5 Member's Car Journals 85 01-08-2015 01:09 PM
FR-S driver01 Forced Induction 78 07-04-2013 10:07 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
