Old 10-31-2012, 02:20 PM   #29
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
just to let you guys know, you don't have to tape off the actual tire with newspaper and tape. If you get over spray you can just peel it off , depending on how many coats you applied. I did 4 coats and it came off clean.
And another thing, if you do do this, remember to cut the plasti-dip from where the lug nuts go. I made the mistake of not doing this and when I was putting the wheels back on it started to peel from the inside. Now I have to redo them again.
Style is offline   Reply With Quote
Old 10-31-2012, 05:43 PM   #30
JDMenrique
DEEEERP
JDMenrique's Avatar
good call
JDMenrique is offline   Reply With Quote
Old 11-02-2012, 05:55 PM   #31
psk
Drives: scion fr-s
here is an example of black base plasti dip + silver metalizer
psk is offline   Reply With Quote
Old 05-29-2013, 03:26 AM   #32
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Plasti Dipped the wheels white on my red BRZ love how it looks
The Following 3 Users Say Thank You to ChandlerSwyng For This Useful Post:
JDMenrique (05-29-2013), SoNotCool (04-15-2017), stratodyne (09-05-2013)
Old 05-29-2013, 10:54 AM   #33
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I was actually going to try this out using white -- thanks! I'm definitely going to do it!.
going to spray over the scion logo as well. White plastidip looks really nice on those wheels now.
CamryDS is offline   Reply With Quote
Old 05-29-2013, 11:31 AM   #34
chjno86
a/k/a ikuzOtaku
chjno86's Avatar
Drives: Whiteout FRancheSka
any tips on how to plastidip it without have to remove the rims? i dpnt have enough jacks to remove all of them.... or maybe i should do them one at a time... hmmm
chjno86 is offline   Reply With Quote
Old 05-29-2013, 11:41 AM   #35
ML
ML's Avatar
Drives: 13 White MT FR-S
and here is my wheel after about 2 months.
The Following User Says Thank You to ML For This Useful Post:
Lav (03-01-2019)
Old 05-31-2013, 02:21 PM   #36
Jimp
No longer a lurker
Jimp's Avatar
Drives: 2013 6MT SWP BRZ LTD
Not bad... I am assuming the peeling on the inside of the spokes is just general wear and tear? At least it seems like it protected the wheel well.
Do you plan on taking the plasti-dip off and doing it again?
Also, how much did you guys spend to do this? Like $20-$40 for the plasti-dip?
Jimp is offline   Reply With Quote
Old 06-03-2013, 12:05 PM   #37
sklimo
Old 06-03-2013, 02:11 PM   #38
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
You can actually plastidip the wheels without taking them off. Couple of tips:
-pull some plastic/news paper through the spokes and cover your brakes (calipers, rotor, etc.) you don't want plastidip on those
-As somebody mentioned, its not necessary to completely cover your tires (w/ news paper, etc) but you probably would want to cover your body panels, fenders, etc. Just easier to remove those instead of carefully peeling off.
-Make sure to roll your car forward/backward (to rotate the wheels) every or every other coat, this way you spray every angle of the wheel and get a nice even coat.
Or... do them 2 at a time (front, then back) or just get another set of jack stands, they do come in handy. Have fun!
Old 06-03-2013, 02:37 PM   #39
PMok
Codename: Stitch
PMok's Avatar
mine held up pretty well for the last 6 months... but started peeling a little on the side of the spokes and around the edge of the rim. Pretty good considering all the driving and even 2 track days. Time for a respray... I just started to peel it off one of the rims yesterday, it is actually a bit of a pain to take off. Probably because I didn't spray enough thickness on, but also because the spokes are fairly thin and it doesn't come off in fat pieces like it would off a wide spoked rim.
I take my wheels off to spray them, makes it easier to make sure you didn't miss a spot.
Anyways I am thinking instead of peeling the rest off I will just respray the other wheels that are still in decent condition. Also trying a different color, just ordered 4 cans of the new Anthracite color and the glossifier from dipyourcar.
Old 06-03-2013, 09:32 PM   #40
Jimp
No longer a lurker
Jimp's Avatar
Wow, nice! Please post some pictures when you get the chance to re-dip those suckers. The anthracite looks like it might be pretty awesome.
Old 06-04-2013, 12:21 PM   #41
Xdragonxb0i
Drives: ex500r
I probably do this weekend, but with a twist =D
Xdragonxb0i is offline   Reply With Quote
Old 06-04-2013, 01:36 PM   #42
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I was having a hard time getting the brake dust off after a track day yesterday. Seems the brake material is stuck on the plasti dip
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Plastidip Smoke Sutty Cosmetic Modification (Interior/Exterior/Lighting) 1 09-29-2012 05:04 PM
plastidip practice on the FR-S nytfury Cosmetic Modification (Interior/Exterior/Lighting) 18 08-27-2012 02:35 PM
Plastidip emblem??? jarviz Cosmetic Modification (Interior/Exterior/Lighting) 20 08-02-2012 03:21 PM
Plastidip and Vinyl Help CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 8 07-25-2012 01:56 PM
A little plastidip test raphymartinez FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 06-11-2012 08:45 AM
