Correct barb size for catch can?
I believe the outlet size is 1/2 (0.5") but what about the inlet? I know some people running 0.425" but is that the ideal size or should it be 3/8?
#2 |
I Love custom Turbo kits
Drives: Limited BRZ
I'm PREEEEEETTY sure its 1/2" for inlet also.
#3 |
#4 |
Drives: Limited BRZ
I have the D3PE catch can, and I'm sure it uses 1/2 for outlet (I clamped both) I'll check the inlet tonight. It might be 3/8" on the top of the throttle and 1/2" on the other side. I have no inlets as it vents to ATM, but I'm using the top of the throttle as my pressure signal for Gauge and BOV.
#5 |
I'm 99% sure the inlet is 3/8", the outlet is 1/2". Where 3/8" is the PCV hose and 1/2" is to the intake manifold. You can pull off the PCV hose in about 2 seconds and measure it, it's not clamped or anything.
I'm using the Radium can and I'm using a 3/8" inlet and a 1/2" outlet. |
#6 | ||
#7 | |
Drives: Limited BRZ
#8 |
#9 | |
Drives: Limited BRZ
The Breather side is 1/2" to 1/2", no reducers. What catch can do you plan on using?
#10 | |
I'm planning to go with the Saikou Michi can. Last edited by Hanakuso; 05-24-2013 at 01:53 PM. |
#11 |
Drives: Limited BRZ
PCV is inside the block, so the conection in the block is 1/2" im 95% sure about that one (Could definitely be wrong!!). The top of throttle body (that is the oulet fo the PCV) is reduced to 11/32" only the designers know why... The breather which is below the AC compressor and connects to the intake tube, im 95% sure its 1/2 to 1/2, maybe I didnt explain it well initially?
#12 | ||
#13 |
-6AN or 3/8ths is the inlet size barb. 3/8th hose can be run from PCV Valve to inlet of catch can.
Output to intake manifold is 1/2" hose and barb. As pictured. Make sure every piece is clamped and PCV leaks are very common and can cause performance issues.
#14 | |
Drives: Limited BRZ
The inlet into the throttle seemed perfectly 1/2" so that means inlet to PCV is 11/32".
| DIY: ReWire AT Shifter to Reverse & Correct the +/- pattern (on selector stick) | ymboc | DIY (Do-It-Yourself) Guides | 11 | 04-02-2022 05:07 PM |
| correct idle rpm after warmup | StormTrooper | Issues | Warranty | Recalls / TSB | 11 | 04-27-2013 07:00 PM |
| Think all tires of the same size ARE the same size? | Draco-REX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-26-2012 08:41 PM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| Fitting 9.5" wheels in back.. is my math correct? | eikond | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 05-23-2012 02:19 PM |
