Old 08-02-2012, 09:06 PM   #1
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Think all tires of the same size ARE the same size?
Think again.
I just put some Yokohama Advan AD08 tires on my BRZ and I went with a 235/40-17 size.
Here are some comparison pics:
This is the new tire on an 8" wheel compared to the old one on the stock rims.
Looks bigger, but you would expect that. One's an OEM touring tire, the other is an aftermarket Extreme Performance tire made for AutoX.
But look at this comparison:
Again, new tire on 8" wheel on the right. The left tire is also on an 8" wheel, but it's a 245/40-18 Continental ExtremeContact DW (which Tire Rack doesn't seem to carry any more. ) I knew something was up when I noticed my new tires had more pinch than the 245s I had for my Legacy.
The 235 AD08 is listed as a 9.5" sec width, and the 245 ECDW as a 9.8" sec width at Tire Rack, but they're nearly identical in width when mounted to the same width wheel. So if you're going to be pushing the limits of what will fit, always double-check the tire width. If you go with a really high performance tire, be aware that the tire manufacturer might have fudged some numbers to get as much width as possible for the size.
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
86-tundra (12-03-2013), Anthonytpt (05-01-2013), teppei (03-05-2018)
Old 09-26-2012, 11:15 AM   #2
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
How about the effects of the overall diameter? I believe the stock ones are 24.6,, would be the same with the 245/40 AD08 also at 24.6, but your 235/40 is at 24.4 (specs at tire rack). Going to a -.2 overall diameter, what would be the side effect?
pinoy_dorifto is offline   Reply With Quote
Old 09-26-2012, 11:53 AM   #3
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
New tires with labels on them..ugh I miss summer weather already. Next season can't come soon enough!
Tt3Sheppard is offline   Reply With Quote
Old 09-26-2012, 03:24 PM   #4
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
1% speedometer and odometer error, which is inconsequential, as most cars come from the factory with that much error or more. You can have that much difference in diameter going from a full tread 10/32" tire wearing it down to 3/32". I've had tires that varied as much as 5% in diameter from stock in the past, but try not to go more than that.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
Adeets (02-18-2013)
Old 09-26-2012, 03:36 PM   #5
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Each tire has a specific rim width range on which the tire can be mounted. The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10". Some vehicle manufacturers and tire companies have permitted rim widths that are not within the tire's original approved rim width range. ie.... BMW M3 & M5 and Chevrolet with almost all the Corvettes from 65 up. This effects height also thus effecting fittment.
This is a calculation I used when I was a Team TA member
Divide Width by 25.4 (25.4 = 1')
Multiply that sum by (aspect ratio = side wall height)
Multiply that total by 2 ( top of tire + bottom of tire)
Add that total to Rim diameter
Example:
235/40r-17
235 / 25.4=9.25 Section width from sidewall to sidewall
9.25 * 40% = 3.70 Aspect Ratio ie Sidewall Height
3.70 + 3.70 =7.4 Top sidewall height & Bottom Sidewall height
7.40+17=24.40 Height of tire
Spartan65 is offline   Reply With Quote
Old 09-26-2012, 08:41 PM   #6
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Typically tire manufacturers are allowed a % variance on a given size.
Many of the track-geared tires will utilize the maximum allowed variance for grip, and they are more flat to allow for more tire contact patch.
We did some similar comparisons too a while back.
265's - big differences!
Touge Factory is offline   Reply With Quote
bulb size for frs brichard0625 Exterior Parts - The Rest 4 07-23-2012 03:33 PM
Lug size Chewie4299 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-06-2012 12:32 AM
BRZ - NC Miata Size Comparison engee BRZ Photos, Videos, Wallpapers, Gallery Forum 3 07-05-2012 04:06 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Size Comparison: FR-S versus tC and GT-R CSSM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 58 03-05-2012 10:28 PM
