Old 04-26-2013, 04:08 AM   #1
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
correct idle rpm after warmup
So reading all the issues I've failed to find any aside from having at least 3 different idle rpms and hanging when shifting into neutral.
I would think a 2.0L would idle around 800 not 650 but maybe I'm wrong?
Also dealer claims my vin has no recalls or TSB's listed.
Thanks.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 04-26-2013, 07:41 AM   #2
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
idle without a/c should be 650.
With a/c sometimes it goes to 800 when compressor kicks-in.
gzpermadi is offline   Reply With Quote
The Following User Says Thank You to gzpermadi For This Useful Post:
CamryDS (04-26-2013)
Old 04-26-2013, 08:39 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks.
Being a 2.0L has very little to do with idle RPM.
As a side note, a Visconti tune will raise your idle RPM to a cool ~900 and it idles awesome.
Old 04-26-2013, 09:34 AM   #4
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Just about 600 - 650
compressor kicks in it's about 800-900
Reason why i'm not giving exact numbers? Because There's no digital display. So around this area, you should be fine -- though it has to be steady.
CamryDS is offline   Reply With Quote
Old 04-26-2013, 11:07 AM   #5
roddy
roddy's Avatar
Drives: '13 Ultramarine
Mine idles rock steady between 6-700 (I'd call it 650) on the tach. I often get a slight stumble on tip-in, and I'm pretty sure a slightly higher idle would help this out. I wonder if this is something the dealer could adjust.
Old 04-26-2013, 11:17 AM   #6
PANDA86
Old School Status
Drives: .
after warm up (appox. +/-1min.) idle settles @ 650rpm on my scangaugeII
PANDA86 is offline   Reply With Quote
The Following User Says Thank You to PANDA86 For This Useful Post:
Old 04-26-2013, 11:24 AM   #7
wheelhaus
wheelhaus's Avatar
It does idle pretty low for a 4-cyl. 600rpm would cause other 4's (even other Subarus) to stumble. I believe it's due to the additional fuel control offered by direct injection, since it can precisely alter the mixture even after the port injectors have done their part. It could also simply be due to ECU programming, since the ECU will catch the RPM when it falls to around 1000, and then gently lower it to 600. Seems to work better than letting the rpm fall freely and then catch it right at 600.
wheelhaus is offline   Reply With Quote
Old 04-26-2013, 01:47 PM   #8
StormTrooper
The reason I mention engine size is that I've owned several cars and the 4cyl ones idled higher to the tune of 800+ while the 5.3L Chevy and 2.8l vw were s little lower but still over 650. More like 750.
Also it seemed to settle into the 850/900 area a few minutes after startup then drop down much later so I was curious if the reflash for wandering idle set the new warm value further up or not.
Only seen desiel trucks this low....
GR86 MT premium
Old 04-27-2013, 02:06 PM   #9
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
My Eclipse GSX which is a sporty 2.0L inline 4 idles at only 500 RPM. Although I noticed it's much smoother if I hold the throttle at 900 RPM. But yeah, as Marchy said, I'm sure it's a matter of keeping it as low as possible for fuel savings.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-27-2013, 02:58 PM   #10
QuikSilveRX-8
QuikSilveRX-8's Avatar
Drives: SE3P
That is your answer there... A mechanical "analog" needle shows only an approximation of the digital value from the CAN bus data that is fed to the dashboard and displayed to the driver.
Three moving engine parts, yet complicated... Or do I mean complex?
QuikSilveRX-8 is offline   Reply With Quote
The Following User Says Thank You to QuikSilveRX-8 For This Useful Post:
CamryDS (04-27-2013)
Old 04-27-2013, 07:00 PM   #11
CamryDS
DIY: ReWire AT Shifter to Reverse & Correct the +/- pattern (on selector stick) ymboc DIY (Do-It-Yourself) Guides 11 04-02-2022 05:07 PM
Idle dip ONLY with COMPRESSOR on #87 Issues | Warranty | Recalls / TSB 2 11-14-2012 11:12 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Fitting 9.5" wheels in back.. is my math correct? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-23-2012 02:19 PM
