Old 05-23-2013, 04:11 PM   #1
Hanakuso
Correct barb size for catch can?
I believe the outlet size is 1/2 (0.5") but what about the inlet? I know some people running 0.425" but is that the ideal size or should it be 3/8?
Hanakuso is offline   Reply With Quote
Old 05-23-2013, 09:21 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'm PREEEEEETTY sure its 1/2" for inlet also.
Old 05-24-2013, 02:12 AM   #3
Hanakuso
Hmm interesting. People in the DIY are doing 1/2 for outlet and 11/32 to 3/8 for inlet. These sizes are for the tubing.
Im guessing bigger would be safer then smaller, but I rather get the sizing a close to OEM.
Old 05-24-2013, 07:47 AM   #4
Sportsguy83
Drives: Limited BRZ
I have the D3PE catch can, and I'm sure it uses 1/2 for outlet (I clamped both) I'll check the inlet tonight. It might be 3/8" on the top of the throttle and 1/2" on the other side. I have no inlets as it vents to ATM, but I'm using the top of the throttle as my pressure signal for Gauge and BOV.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Hanakuso (05-24-2013)
Old 05-24-2013, 10:06 AM   #5
xwd
I'm 99% sure the inlet is 3/8", the outlet is 1/2". Where 3/8" is the PCV hose and 1/2" is to the intake manifold. You can pull off the PCV hose in about 2 seconds and measure it, it's not clamped or anything.
I'm using the Radium can and I'm using a 3/8" inlet and a 1/2" outlet.
The Following 2 Users Say Thank You to xwd For This Useful Post:
Hanakuso (05-24-2013), Sportsguy83 (05-24-2013)
Old 05-24-2013, 12:03 PM   #6
Hanakuso
The only thing I don't understand is why it would be different. We are basically just throwing a catch can in the middle of the line right? You would think that OEM line would be the same from inlet to outlet.
Old 05-24-2013, 01:07 PM   #7
Sportsguy83
Drives: Limited BRZ
I know... but the Designers had others things in mind..
Old 05-24-2013, 01:11 PM   #8
Hanakuso
Wait what do you mean? Do you mean not having a stock catch can or the size of the hoses?
Old 05-24-2013, 01:15 PM   #9
Sportsguy83
Drives: Limited BRZ
You said the hose size should be same on both sides, I mean the designers had different things in mind because they used reducers to connect the PCV hose from the block to the throttle. Now that I'm writing this its all coming together actually. The PCV side, its 1/2" in the block and 11/32" on top of the throttle.
The Breather side is 1/2" to 1/2", no reducers.
What catch can do you plan on using?
Old 05-24-2013, 01:23 PM   #10
Hanakuso
Ahh I see! I'm assuming 3/8 inlet would be a good compromise? Btw, I believe you got the PCV and throttle sizes mixed up. It should be other way around.
I'm planning to go with the Saikou Michi can.
Old 05-24-2013, 02:14 PM   #11
Sportsguy83
Drives: Limited BRZ
PCV is inside the block, so the conection in the block is 1/2" im 95% sure about that one (Could definitely be wrong!!). The top of throttle body (that is the oulet fo the PCV) is reduced to 11/32" only the designers know why... The breather which is below the AC compressor and connects to the intake tube, im 95% sure its 1/2 to 1/2, maybe I didnt explain it well initially?
Old 05-24-2013, 02:30 PM   #12
Hanakuso
This is what is making me confused with the explanation.
Originally Posted by Dezoris View Post
23. Grab 18" of 1/2" PCV hose and connect it from the intake manifold and then to the outlet of the catch can push it on there, use hose clamps if you want to.
24. Grab 18" of 11/32" PCV hose and connect it from the PCV valve to the catch can inlet. Don't be a chud, if it feels loose use hose clamps.
This is my config that I submitted to Saikou Michi. I hope it's correct!
The Following User Says Thank You to Hanakuso For This Useful Post:
Apex Chase (05-24-2013)
Old 05-24-2013, 03:11 PM   #13
Dezoris
Dezoris's Avatar
-6AN or 3/8ths is the inlet size barb. 3/8th hose can be run from PCV Valve to inlet of catch can.
Output to intake manifold is 1/2" hose and barb. As pictured.
Make sure every piece is clamped and PCV leaks are very common and can cause performance issues.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
Old 05-24-2013, 03:48 PM   #14
Sportsguy83
Drives: Limited BRZ
I was redoing my Pressure signal line and I think you were right and I was wrong.
The inlet into the throttle seemed perfectly 1/2" so that means inlet to PCV is 11/32".
DIY: ReWire AT Shifter to Reverse & Correct the +/- pattern (on selector stick) ymboc DIY (Do-It-Yourself) Guides 11 04-02-2022 05:07 PM
correct idle rpm after warmup StormTrooper Issues | Warranty | Recalls / TSB 11 04-27-2013 07:00 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Fitting 9.5" wheels in back.. is my math correct? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-23-2012 02:19 PM
