Old 05-22-2013, 12:25 PM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nice work on the part numbers and PDF Opie. Don't He-Man your new oil filter on next time OP. General rule is turn till seated and then a 1/4 turn. You should be able to get the filter back off without the use of a tool if torqued properly.
Old 05-22-2013, 12:27 PM   #30
oofie
Originally Posted by Opie View Post
Just threads right in, tighten to 33.2 ft/lbs. See attached.
great post!
oofie is offline   Reply With Quote
Old 05-22-2013, 03:06 PM   #31
frslee
Just drive it
Drives: 13' FR-S
@davtbaum Did you get the thread replaced? Try not to use FRAM filter... look up some videos in Youtube. I'm sure they have improved over time, but their general oil filter sucks.
frslee is offline   Reply With Quote
Old 05-22-2013, 03:19 PM   #32
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Unless it's the factory filter. I swear that every new car I've ever had, first time oil change always sucks getting the original filter off.
Chimpo is offline   Reply With Quote
Old 05-22-2013, 03:51 PM   #33
DJCarbine
Thupercharged
DJCarbine's Avatar
How did the seal surface get scratched?
The only thing that contacts that surface is the rubber seal of the oil filter....
It just screams overtorqued oil filter, but you said you tightened by hand. Meaning only using your hand, and not any tools right? I knew someone who thought tighten by hand meant using an oil filter socket and a breaker bar, because they are "hand tools"
DJCarbine is offline   Reply With Quote
Old 05-22-2013, 04:14 PM   #34
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Definitely tightened by hand!
What I found interesting is the location of the stripping. I ended up getting the bolt out using a 24mm deep socket. After pulling it out I could see that the first two thread rotations are in tact. The following 2.5 and stripped, and the last threads are in tact as well.
Here's a pic
Now this follows the resistance when screwing the filter back on - the first two rotations are easy, the following 2 are really tough, then easy again.
Now if this is over torquing would l that not imply the stripping of the initial threading on the bolt? I'm not sure, but I know I hand tightened the filter when putting it on.
davtbaum is offline   Reply With Quote
Old 05-22-2013, 05:46 PM   #35
celica73
Looks like galling to me (materials mismatch). That's a really weird failure. I'm guessing some sort of thread defect on one of the two parts involved, but it's hard to say which is the chicken and which is the egg. At least it was a cheap part!
Old 05-22-2013, 05:59 PM   #36
DJCarbine
Thupercharged
DJCarbine's Avatar
More than likely bad threads on the filter, perhaps there were slivers of metal that broke free when you tightened it and ended up fubaring the threads... but I've never seen/heard of that
I've seen some weird crap though, my overpipe to header bolts BOTH galled the thread on removal, and ended freezing/snapping the bolts off because they refused to loosen any more than 2mm or so even though they looked brand new.
Still doesn't explain the surface scratching, did the oil filter go on slightly lopsided so the edge of the oil filter was able to hit the mounting surface before the gasket? That would support the bad thread theory
The Following User Says Thank You to DJCarbine For This Useful Post:
SkullWorks (05-23-2013)
Old 05-22-2013, 10:33 PM   #37
Ozzman
Drives: old
In 8 years of working on cars professionally, I have never seen that happen, wow. I've seen enough stripped drain plugs to fill a gallon paint can, a few stripped drain pans, and even oil filters that leaked through the casing. But have never seen a filter union/stud stripped.
Maybe it wasn't properly heat treated, who knows; but that aint right.
Ozzman is offline   Reply With Quote
Old 05-22-2013, 11:15 PM   #38
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I'm going to say it was probably during removal if it went on with no problem. I've seen a thread failure very similar to that, but the threaded piece itself had a small cut-out area for staking of the nut. If you didn't unstake the nut perfectly, any small piece of debris or no longer exactly lining up thread would destroy the piece in a similar fashion. Very frustrating to try and remove a nut, and every now and then you ruin the much more expensive part it's attached to.
Old 05-23-2013, 06:24 PM   #39
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Hey guys, an update
Got the part in today. Overnights from Subaruparts - thanks @Opie for the diagram and part number!
A comparison with the old bolt
Getting the new union on was trivial, torquing to 33.2 ft lbs. Installing the filter afterwards was as simple as a normal oil change
Got my car running again - thanks guys!
The Following 6 Users Say Thank You to davtbaum For This Useful Post:
charged86 (06-02-2013), FrX (05-28-2013), Jar (05-31-2013), Opie (05-23-2013), Sevs753 (05-23-2013), SkullWorks (05-23-2013)
Old 05-23-2013, 06:55 PM   #40
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
An they lived happily ever after
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Sportsguy83 (05-24-2013)
Old 05-29-2013, 02:14 PM   #41
OuHiroshi
OuHiroshi's Avatar
Drives: Saab 9-5 3.0t
Originally Posted by davtbaum View Post
Hey guys, an update
Looked like you can just flip the stripped union around and put it back in #ShittyAdvice
It definitely looked like a manufacturing defect on the union and the low quality Fram thread put the nail on the coffin.
OuHiroshi is offline   Reply With Quote
The Following User Says Thank You to OuHiroshi For This Useful Post:
davtbaum (05-29-2013)
Old 05-30-2013, 02:34 PM   #42
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Hey guys, an update
Nice E30 bro. Could definitely be treated to a new roundel though.
davtbaum (05-31-2013)
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 02:50 PM
Looking for 2 - 12mm jam nuts with fine threading.... MidLife&luvIt Northern California 18 06-17-2013 01:27 PM
Fr-s shift knob threading iam_abner Cosmetic Modification (Interior/Exterior/Lighting) 3 08-06-2012 09:05 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 08:16 AM
