Old 05-21-2013, 07:04 PM   #1
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Oil filter threading stripped
Hey guys,
Not a good day for my BRZ. What started as a simple oil change turned into a much bigger issue when I found that the threading on the oil filter housing was stripped after I pulled off the old filter. I also found that some the surface of the seal was scratched and chipped . I am currently unable to obtain a seal with the new filter so my car is not drivable.
I believe the old filter (fram) was the culprit of the stripped threading but the cause of the surface damage is still to be determined. My questions are:
Does anyone know if the threading key is replaceable? It appears as if it can be unscrewed. If it is it would save me a tow to the dealer.
Any chance the dealer would cover this? It was definitely the filter that cause the threading to strip, but as I replaced it myself I'm sure they would fight that.
I'm posting this on my phone but ill upload pics once I get home.
Thanks guys,
David
davtbaum is offline   Reply With Quote
Old 05-21-2013, 07:07 PM   #2
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Did you change the oil last? I would think you would notice if it was cross threaded...
Interested to see pics. Bummer man.
As far as fixing it... maybe there's a die big enough to use, but you'd have to worry about shavings. On top of that, depending on how "screwed" it is would it be enough to salvage the existing piece??
Chimpo is offline   Reply With Quote
Old 05-21-2013, 07:28 PM   #3
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Threading key is replaceable, it's called a filter union. Subaru P/N: 15018AA150
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 05-21-2013, 07:36 PM   #4
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Last oil change i didn't see any cross threading - and I don't remember the filter being tough to get on. But yeah shavings are what I'm most worried about.
Old 05-21-2013, 07:37 PM   #5
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Wow this is great thank you!
Old 05-21-2013, 07:42 PM   #6
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
it wasn't on an frs so I don't know if that particular one is removable, but I have removed an oil filter stud once. if you want to save the one you have, you need two bolts that will fit onto it, tighten the two nuts together and use a wrench on the bottom nut to loosen the stud. if the stud is stripped and you can't reuse it you could use vise grip pliers to unscrew the stud if it is removable. I guess the problem might be finding a new stud since the car is so new.
beaver_scott is offline   Reply With Quote
Old 05-21-2013, 08:21 PM   #7
s0sl0w
Proud of Boxer
I would use a OEM filter as well... it's like $8 at the dealer.
s0sl0w is offline   Reply With Quote
Old 05-21-2013, 09:07 PM   #8
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Here are the pics - the first image you'll see the stripped threads and the second is the surface chips.
Old 05-21-2013, 09:09 PM   #9
leon78
leon78's Avatar
Drives: 13 Whiteout
Good time to by an oil cooler..replace the oil filter stud and be full of win... : )
Sent from my yotaru
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 05-21-2013, 09:16 PM   #10
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
According to this diagram the stud is part of the entire outing timing housing
Old 05-21-2013, 09:26 PM   #11
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Where did you get this P/N, I can't find it online
Old 05-21-2013, 09:38 PM   #12
fasteddy
Even if that part is not available I wonder if you could unthread the boss for the filter and clean up the threads off the car? It looks like it might unscrew?
I have heard of issues and avoided Fram for many years. You can't go wrong with a stock filter. First impression is that the filter was over tightened when installed.
Good Luck!
Pat
fasteddy is offline   Reply With Quote
Old 05-21-2013, 09:44 PM   #13
davtbaum
davtbaum's Avatar
Drives: Subaru BRZ
Good Luck!
Pat
Yep I'm going to attempt to unthread tomorrow, and seat the oil filter on that. Otherwise it's off to the dealership
Old 05-21-2013, 09:47 PM   #14
Ozzman
Drives: old
I have a hard time believing the filter union is stripped, that part should be made out of hardened steel. The discoloration is more likely material from the threads on the filter itself. Can we get a pic showing the side of the filter union instead of the top of it?
Ozzman is offline   Reply With Quote
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Looking for 2 - 12mm jam nuts with fine threading.... MidLife&luvIt Northern California 18 06-17-2013 12:27 PM
Fr-s shift knob threading iam_abner Cosmetic Modification (Interior/Exterior/Lighting) 3 08-06-2012 08:05 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
