Old 05-17-2013, 10:16 AM   #1
normanb21
Drives: black frs
Just installed crash bolt.
I just put the 901000394 camber bolts in the front. I figured some people would line to see the difference so heres a pic of before and after. Can anybody estimate the camber I have right now?Name:  ImageUploadedByTapatalk1368800171.871990.jpg
normanb21 is offline   Reply With Quote
The Following User Says Thank You to normanb21 For This Useful Post:
Anthonytpt (05-17-2013)
Old 05-17-2013, 10:28 AM   #2
cnk
Drives: '13 DGM BRZ Limited
No. . but I didn't stay at a Holiday Inn last night so maybe that's why.
You could get a rough estimate with a plumb line, a tape measure, and some trig.
The Following User Says Thank You to cnk For This Useful Post:
Old 05-17-2013, 10:36 AM   #3
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
I need me some camber.
Anthonytpt is offline   Reply With Quote
Old 05-17-2013, 10:50 AM   #4
hapa_kcm
hapa_kcm's Avatar
Drives: WRB BRZ Limited
I can tell you after installing those bolts and a 1" drop I had -1.5°
hapa_kcm is offline   Reply With Quote
Old 05-17-2013, 10:57 AM   #5
troek
troek's Avatar
Drives: 2012 Toyota 86
theres an app called clinometer if you have an iphone. its been accurate within .1 degree on me and my buddies cars after alignment.
troek is offline   Reply With Quote
Old 05-17-2013, 11:33 AM   #6
eljefe
Drives: SS BRZ LMTD 6MT, 92 Civic hatch RHD
Are you guys trying to correct your camber, or get it to be more negative? im confused.
When i dropped my car the rear went negative so i want to bring it back to zero, obviously i cant use these cam bolts, so is my only option to buy 500 dollar LCA's?
eljefe is offline   Reply With Quote
Old 05-17-2013, 11:35 AM   #7
normanb21
Drives: black frs
I was tryin to get more negative. I'm still on stock ride height
Old 05-17-2013, 11:39 AM   #8
cnk
You have a few options.
1. Raise the car up
2. Get LCA's
3. Get UCA's
4. Get Whiteline UCA bushings
5. Some have used a modified camber bolt in the LCA to subframe connection to get some camber adjustment.
eljefe (05-17-2013)
Old 05-17-2013, 11:51 AM   #9
normanb21
Drives: black frs
Oh thanks, this app is awesome. I could probably figure out the toe too
Old 05-17-2013, 02:09 PM   #10
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
SPC LCAs are only $300, i went this route
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following User Says Thank You to f0rge For This Useful Post:
deucethemoose (05-19-2013)
Old 05-17-2013, 02:35 PM   #11
mad_sb
Drives: 2013 Asphalt FR-S
I hope you plan on an alignment .. change to camber changes toe as well and you really need to set it up properly if you want it to handle correctly. camber is almost never the same side to side stock, so maxing out the lobe on the crash bolts will not result in the same camber on each side and as a result toe will not only change, but likely go wonky (more toe in or out one side than the other).
Old 05-17-2013, 04:00 PM   #12
normanb21
Drives: black frs
Ok thanks for the info. Anybody know how to adjust toe?
Old 05-17-2013, 05:50 PM   #13
mad_sb
Adjust or measure?
A few ways to measure, search google and youtube.
To adjust, look at the tie rod ends for a lock nut, the look on the steering arm for an octagonal section designed for a wrench, loosen the lock nut, turn the arm to adjust, re tighten lock nut.
Unless your going to spend a lot of time making 4 level (with each other) slip plate platforms (cheap way is using water level, floor tiles, and table salt) and learning to do a full string alignment, your better off going to a reputable shop.
It's very easy to screw your alignment up. Better off to get a good alignment to start with, then see if you can perfect your measuring system to get the same numbers they got on the rack. Then, make a few small changes and see if you can get it back to the original settings etc etc.
Old 05-17-2013, 06:45 PM   #14
jeebus
you probably have around 1 degree. That's all I was able to get with crash bolts. Now that I have RCE yellows and crash bolts, I have 1.4
jeebus is offline   Reply With Quote
Crash Bolt Part Number? Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 10-18-2013 12:02 AM
Crash bolt installation question slowbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-01-2013 12:37 AM
Trying to find service manual info on crash bolt 2point0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-17-2012 02:07 PM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 01:22 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
