Old 05-15-2013, 02:10 AM   #15
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Originally Posted by Tylub View Post
since my 22.5k mile service, they put back in green coolant and it's been pretty consistent. No major changes and my coolant "leak" stopped as well. They might have done something, maybe not, who knows..
I would take it back immediately and insist that they use the proper(blue) coolant. I would think this may cause you trouble down the line if you need warranty work, you take it in and they tell you that you replaced it with the wrong stuff, warranty voided on their fail!
Cade01 is offline   Reply With Quote
The Following User Says Thank You to Cade01 For This Useful Post:
Tylub (05-15-2013)
Old 05-15-2013, 03:01 AM   #16
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
so let me get this straight.. the proper coolant is BLUE not green?
mine was green from day 1 -.-
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 05-15-2013, 08:51 AM   #17
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Mine was green as well.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-15-2013, 09:27 AM   #18
andrew20195
Drives: 2013 Subaru BRZ
Subaru offers green and blue colored coolant. It is a phosphate type ethylene glycol mix. The green coolant is non-premixed with water, while the blue is premixed 50/50. They are compatible with each other.
I presume Scion uses coolant from the same manufacturer on the FR-S, so it would be the same color. I know Toyota normally uses their own red colored coolant.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
strat61caster (05-15-2013)
Old 05-15-2013, 06:05 PM   #19
Conor
Drives: '93 Toyota MR2 - V6
Yep, the Scion is 100% Subaru and Toyota dealerships now stock Subaru parts/fluids to service them. Toyota boxes with "SU" part #s. Aaaaaand in California some dealerships stock Tesla coolant, too! (for the Rav4 EV)
Conor is offline   Reply With Quote
Old 06-19-2013, 01:15 PM   #20
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
they use subaru blue coolant for frs and brz....toyota uses red for all their cars
driftartist is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Turn signal amber LED's flashing quickly michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 11 07-13-2012 10:55 PM
Does the ECU adjust quickly to octane change? Evil86 Engine, Exhaust, Transmission 2 07-02-2012 07:30 PM
well, that escalated quickly. xjohnx Mid-Atlantic 9 07-01-2012 10:08 PM
