Old 02-01-2013, 04:25 PM   #1
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Green engine coolant used quickly?
haven't found my answer and the tech's think i may have a leak.. or they think the car just uses a lot of coolant.
possibilities: i didn't have a snorkel for the past 9000 miles and maybe the hot air caused my engine coolant to be used up?
well anyways.. they filled up the green coolant all the way to full and again it's at a 1/4 now. not due to burping or air in the tank.
anyone else having these issues? i put back the snorkel just in case
(had the snorkel off due to intake... but reverted to stock because I bogged like a MF )
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 02-01-2013, 08:51 PM   #2
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Stock coolant blue aint it?
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 02-01-2013, 09:37 PM   #3
whtchocla7e
Drives: 2013 FR-S Hot Lava
blue like the sea
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 02-01-2013, 10:36 PM   #4
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
When you checked the engine coolant was the vehicle on idle or was it off?
ArKiTeCkT is offline   Reply With Quote
Old 02-01-2013, 11:03 PM   #5
whataboutbob
AutoX-10/10ths every run
Mine's been losing coolant too, but not at the same rate as yours.
Build thread:Here
Old 02-02-2013, 01:33 AM   #6
ahausheer
Re-member
Drives: Toyota camry
I think the techs should have pressure tested the cooling system. You can rent a pressure tester from many auto stores if you want to try and test the system yourself. The test doesn't take very long and should help find a leak. By simply filling up the reservoir they are treating the symptoms, not the disease. You may also want to get in writing that they used the ''green'' coolant.
FYI: Cars don't normally ''use'' coolant, hence the extremely long service interval.
Anyone tested the oil for coolant contamination?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-05-2013, 05:10 AM   #7
Tylub
Tylub's Avatar
no tests for oil contamination but coolant is another story.. getting an oil change tomorrow don't know if that will affect anything but it's worth a shot
instagram @Tylub
Old 02-05-2013, 05:11 AM   #8
Tylub
Tylub's Avatar
checked it both times and both were low. Idle seemed lower than off
instagram @Tylub
Old 02-05-2013, 05:12 AM   #9
Tylub
Tylub's Avatar
Originally Posted by whtchocla7e View Post
blue like the sea
strange... mine was green. but I took it to another dealer and they replaced all my coolant with blue coolant
so yeah I guess i have blue coolant now. I wonder what the difference is
instagram @Tylub
Old 02-05-2013, 06:20 AM   #10
czar07
czar07's Avatar
Different chemicals i believe
Old 02-05-2013, 06:08 PM   #11
Robmilkshakes
Drives: '94 Miata R Package
Yeah different additives, it's close, but not compatible.
Robmilkshakes is offline   Reply With Quote
Old 05-13-2013, 09:24 PM   #12
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
@Tylub - How have your coolant levels been lately?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-14-2013, 07:57 PM   #13
Tylub
Tylub's Avatar
since my 22.5k mile service, they put back in green coolant and it's been pretty consistent. No major changes and my coolant "leak" stopped as well. They might have done something, maybe not, who knows..
instagram @Tylub
Old 05-15-2013, 02:04 AM   #14
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
the coolant just evaporates quickly, i think ive filled mine twice and im at 30k miles. but this was only when it was hot, during the winter i never topped it off once and it stayed full the entire time
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Turn signal amber LED's flashing quickly michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 11 07-13-2012 10:55 PM
Does the ECU adjust quickly to octane change? Evil86 Engine, Exhaust, Transmission 2 07-02-2012 07:30 PM
well, that escalated quickly. xjohnx Mid-Atlantic 9 07-01-2012 10:08 PM
