Old 07-12-2012, 01:05 PM   #1
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Turn signal amber LED's flashing quickly
So I could have sworn I saw a post stating the BRZ/FRS didn't care about LED's for any of the lights, no resistors or whatever were needed, but the turn's I put in do flash at the fast (hey a lights burned out buddy) speed, even though they all work.
How do I stop this exactly?
michaelahess is offline   Reply With Quote
Old 07-12-2012, 01:11 PM   #2
Cudgel
Drives: 2008 Mazda3 GT Hatchback
I'm pretty sure you need resistors for the turn signals to stop the hyper flash. All other LED lights shouldn't need it though.
Cudgel is offline   Reply With Quote
Old 07-12-2012, 01:45 PM   #3
M3MPHIS
Drives: 1997 BMW M3, 2013 Subaru BRZ
You my friend need this little guy:
You can get it from superbrightleds.com.
Here is the link: http://www.superbrightleds.com/cgi-b...2Fflashers.htm
Bottom of the page. Part number is CF18-08
Replace the flasher module (under the dash directly in front of the steering wheel) with the one above. If you are having trouble finding it, turn your turn signal on (while in the garage and parked) and listen for it under the dash.... you'll find it, trust me.
This option is much easier and more reversible than hardwiring in load risistors to each led turn signal and you don't have to worry about it getting hot like the load resisters do either.
M3MPHIS is offline   Reply With Quote
Old 07-12-2012, 02:10 PM   #4
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
There are LED bulbs with resistors built into them if you want to avoid all of that^^^
FTEIGHTSIX is offline   Reply With Quote
Old 07-12-2012, 03:56 PM   #5
michaelahess
I like it! Still cheaper than buying the other bulbs I bet. THANK YOU!
Old 07-12-2012, 04:55 PM   #6
michaelahess
So is this the thing that's like sticky taped to the steering column under the dash? It wiggles a lot and has a single cable plug going into it?
Old 07-12-2012, 07:39 PM   #7
michaelahess
eBay has saved me again!
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_3134wt_1163
And yes, I'm patient.
Old 07-12-2012, 08:55 PM   #8
M3MPHIS
It does wiggle, but it's got a clip on it not sticky tape.
I've never heard of the LED bulbs with resistors built in...
Old 07-12-2012, 10:43 PM   #9
michaelahess
So how do you get the clip off? I was fiddling with it for 10 minutes and can't get it to release, almost feels like you have to pinch the sides in but I couldn't manage with my fat fingers.
Old 07-13-2012, 09:44 AM   #10
xcelir8brz
Drives: 2013 BRZ Limited
subscribed
xcelir8brz is offline   Reply With Quote
Old 07-13-2012, 05:18 PM   #11
michaelahess
So following my wife home from getting my windows tinted (she had to drive it ) I noticed the LED turn signals are a lot less noticeable in the rear than the front.
It's not bad enough that someone will rear end me, hell 99.8% of humanity doesn't use turn signals so that's not a problem, but I wanted to let everyone know this.
Obviously when it gets darker or even cloudier outside, they are fine.
Old 07-13-2012, 10:55 PM   #12
M3MPHIS
I used a small flat head to pry it out carefully without damaging it too much.
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
LED exterior and turn signal conversion fenton Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2012 11:33 PM
FR-S / FT-86 Prototype Sound Clips! Startup, On Track, Turn Signal, Seat Belt, Gazoo! Harinjo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 85 01-26-2012 10:17 AM
