| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1317 | |
Theres your front compared to stock I have 9.5 +38 and i poke, so ud poke 10mm more |
#1318 |
My poke |
#1319 | |
Drives: A Potential Traffic Ticket
Rear: 18x9.5 +15 245/35 -2camber -1.6height Front: 18x9.5 +28 245/35 -2camber -2height
#1320 | |
Camber does not affect the center of the rim, so the center (lug area) will be the same poke regardless of camber U have the coils and camber currently? What rim specs? Cause if u have stock rims at that ride, i could tell you how much to measure off the face of the stock wheel to see where these would poke to |
#1321 | |
W/out and w camber/drop Same distance to flush at the hub |
#1322 | |
#1323 |
No, i mean what are u currently running as far as wheels/drop/camber?
#1324 |
Currently on tien h-tech, no idea on camber, with 18x8.75 +35 all over. waiting for the coils to arrive, once i got that in then im gonna replace my wheels and tires.
#1325 |
That setup is 7mm inside the fender, the purposed fronts would be 9.5mm outside the fender based on the web tool
#1326 | |
Drives: FR-S Firestorm 6MT
![]() Doh, yep you are correct. I was thinking of backspacing. |
#1327 |
No worries, made me question all i knew about fitments so i looked it up to be sure lol :p
#1328 |
Drives: 2013 FRS, 2006 Turbo S2000
Fitment
Goal:
Wheels: Enkei RPF1 (17x9 or 18x9?) (ET35 or 45?) Tires: 255/40/** Nitto NT01s Will this fit? And on the FRS, is a 17" or 18" wheel better for tracking? I assume a 17" would be.. So lets say I go 17x9 running 255/40/17 NT01s. Will this fit with ET35 or 45? Also I see a lot of people running 245 rather than 255 for the track.. is this because of fitment? I need the fatter setup because the car will be boosted running ~350-425whp. |
#1329 | |
35 will poke, 45 would leave less clearance at the spring but should fit. Going with the 45 u can always add a spacer, if u go 35 ur stuck w poke wether u like it or not |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
