go_a_way1
Old 05-11-2013, 10:44 AM   #1317
jshadeck
jshadeck's Avatar
Originally Posted by JackSmiley View Post
not gonna do RB til i go FI. so the FRS Project Calculator isnt accurate huh?
Whats not accurate?
Theres your front compared to stock
I have 9.5 +38 and i poke, so ud poke 10mm more
jshadeck is offline   Reply With Quote
Old 05-11-2013, 10:45 AM   #1318
jshadeck
jshadeck's Avatar
My poke
Old 05-11-2013, 10:47 AM   #1319
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Originally Posted by jshadeck View Post
Whats not accurate?
Attachment 36882
coils + camber.
Rear: 18x9.5 +15 245/35 -2camber -1.6height
Front: 18x9.5 +28 245/35 -2camber -2height
JackSmiley is offline   Reply With Quote
Old 05-11-2013, 10:54 AM   #1320
jshadeck
jshadeck's Avatar
coils + camber.
Ok, so the tops of ur tires will poke less and the bottom will poke more lol
Camber does not affect the center of the rim, so the center (lug area) will be the same poke regardless of camber
U have the coils and camber currently? What rim specs? Cause if u have stock rims at that ride, i could tell you how much to measure off the face of the stock wheel to see where these would poke to
Old 05-11-2013, 10:57 AM   #1321
jshadeck
jshadeck's Avatar
coils + camber.
W/out and w camber/drop
Same distance to flush at the hub
Old 05-11-2013, 11:00 AM   #1322
JackSmiley
JackSmiley's Avatar
Eibach R2. as for the wheels, im thinking of getting volk CE28's, and imma do the hub conversion to 5x114.3. but i still havent decided yet.
Old 05-11-2013, 11:04 AM   #1323
jshadeck
jshadeck's Avatar
No, i mean what are u currently running as far as wheels/drop/camber?
The Following User Says Thank You to jshadeck For This Useful Post:
JackSmiley (05-11-2013)
Old 05-11-2013, 11:09 AM   #1324
JackSmiley
JackSmiley's Avatar
Currently on tien h-tech, no idea on camber, with 18x8.75 +35 all over. waiting for the coils to arrive, once i got that in then im gonna replace my wheels and tires.
Old 05-11-2013, 11:12 AM   #1325
jshadeck
jshadeck's Avatar
That setup is 7mm inside the fender, the purposed fronts would be 9.5mm outside the fender based on the web tool
Old 05-11-2013, 03:28 PM   #1326
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Wrong. Offset is the distance from the face of the mounting hub to the center of the rim
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Doh, yep you are correct. I was thinking of backspacing.
Slick is offline   Reply With Quote
Old 05-11-2013, 04:27 PM   #1327
jshadeck
jshadeck's Avatar
No worries, made me question all i knew about fitments so i looked it up to be sure lol :p
Old 05-11-2013, 07:52 PM   #1328
AZ FRS
Drives: 2013 FRS, 2006 Turbo S2000
Fitment
Goal:
Wheels: Enkei RPF1 (17x9 or 18x9?) (ET35 or 45?)
Tires: 255/40/** Nitto NT01s
Will this fit? And on the FRS, is a 17" or 18" wheel better for tracking? I assume a 17" would be..
So lets say I go 17x9 running 255/40/17 NT01s. Will this fit with ET35 or 45?
Also I see a lot of people running 245 rather than 255 for the track.. is this because of fitment?
I need the fatter setup because the car will be boosted running ~350-425whp.
AZ FRS is offline   Reply With Quote
Old 05-11-2013, 08:02 PM   #1329
jshadeck
jshadeck's Avatar
Originally Posted by AZ FRS View Post
Goal:
35 will poke, 45 would leave less clearance at the spring but should fit. Going with the 45 u can always add a spacer, if u go 35 ur stuck w poke wether u like it or not
Old 05-11-2013, 11:07 PM   #1330
JackSmiley
JackSmiley's Avatar
@jshadeck will these fit? 18x9.5 +40 all over.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
