Old 04-24-2013, 09:52 PM   #29
Ohbean
Originally Posted by bdanisi View Post
2500 bucks. Lol. I'll wait for some catted headers. How about a high flow catted front pipe? Would I be ok if I bought catted headers and a high flow catted front pipe, would that set up get me into trouble?
I believe under California vehicle code 'V C Section 27156 Gross Polluter Air Pollution Control Device', you are not allowed to disconect, modify or alter ny emission control device (cat). From what I understand, you may replace a broken cat, but only with a factory part or part approved by the California Air Resources Board.
So technically, even installing a catted header would violate the CA vehicle code.
If you get caught..
Ohbean is offline   Reply With Quote
Old 04-24-2013, 10:07 PM   #30
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
It's so ridiculous I can't swap out my headers legally but this guy in the giant diesel pick up next to me at the light is just pouring out plumes of black smoke...
bdanisi is offline   Reply With Quote
The Following 2 Users Say Thank You to bdanisi For This Useful Post:
CA2 (04-25-2013), Tim_Asphalt_FRS (04-25-2013)
Old 04-24-2013, 10:37 PM   #31
sw20kosh
Drives: 2013 Black FR-S
This wont work. You cannot change the cats period. The only time it is permissible is when it is old and/or failing. Then you can have a stock cat put in (or an OBDII carb certified cat which costs thousands of $$$).
That being said... there are ways of disguising the header catted or not. A simple shroud or heat shield from another vehicle even can be adapted to "cover up" said area. You will have to get creative.
Even after having said that, most cops will not really be able to tell 100% since the headers are underneath the motor. So 9 times out of 10 I would think the cops wouldn't hassle you unless your car had a big fat shiny turbo sitting in front of the motor and bling bling intercooler pipes everywhere and blow off valves galor...etc. Then they will definitely call someone in to inspect you.
Old 04-24-2013, 11:36 PM   #32
Squishy86
Squishy86's Avatar
Drives: Your Car
If you get caught..
Fucking California...
Sent from my SGH-I777 using Tapatalk 2
Squishy86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Squishy86 For This Useful Post:
bdanisi (04-24-2013), CA2 (04-25-2013), Tim_Asphalt_FRS (04-25-2013)
Old 04-25-2013, 01:29 PM   #33
jeebus
They can't do that anymore either. As of a few years ago, all diesels 1998 and later have to have a smog check. They do the visual inspection, OBD2, and a visual smoke test. I just sold my 335d so I know all about it.
CARB cats are not thousands of dollars. My 1988 535is failed smog and I had to replace the cat. I purchased a 50 state, CARB approved, magnaflow for less than $200. However the car does have to be 8 years or older before you can use anything other than an OE cat.
jeebus is offline   Reply With Quote
Old 04-25-2013, 09:27 PM   #34
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
So what I've learned is that swapping the headers and the midpipe is technically illegal. What about the overpipe?
Old 04-26-2013, 01:11 AM   #35
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Overpipe should technically have a CARB EO #, but I doubt a smog tech would notice it down there, it's pretty well hidden. When I get mine, I'm coating it black.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Emissions question with a ecu flash sw20kosh Engine, Exhaust, Transmission 2 04-08-2013 02:11 AM
CA emissions ECU flash recall? icemang17 Issues | Warranty | Recalls / TSB 1 04-05-2013 08:46 PM
Massachusetts Emissions ngabdala New England 3 11-26-2012 08:25 AM
Question about smog checks/emissions showbe Scion FR-S / Toyota 86 GT86 General Forum 3 09-28-2012 01:03 AM
Can the new emissions standards for 2011 alter the ft-86 2jz-gte4life Scion FR-S / Toyota 86 GT86 General Forum 7 04-05-2010 02:16 AM
