Old 04-07-2013, 06:02 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Emissions question with a ecu flash
Does flashing your ecu with an ecuteck tune make you unable to pass CA smog tests where they hook up to the obdII port and check on stuff?
Old 04-07-2013, 07:55 PM   #2
Dynotronics1
Ok thats somewhat of a loaded question, but....we have 10-15 customers in CA runing our EcuTek based tuning. I know of two of them that have gone thru the check stations just for grins(both customers work or own shops that have something to do with inspections) and both passed the tests with no issues.
However, with that said, we sell these for off road use only........
Dynotronics1 is offline   Reply With Quote
Old 04-08-2013, 01:11 AM   #3
sw20kosh
Thanks! I was just curious if they automatically fail you if the ecu looks flashed. I am guessing the readiness codes are all they look for then. With a proper flash these should be fine.
Here is a follow up question: what if you swapped in larger injectors and a fuel pump and flashed it to run these properly. Would it still be ok as long as the readiness codes are fine?
CA emissions ECU flash recall? icemang17 Issues | Warranty | Recalls / TSB 1 04-05-2013 07:46 PM
Massachusetts Emissions ngabdala New England 3 11-26-2012 07:25 AM
Question about smog checks/emissions showbe Scion FR-S / Toyota 86 GT86 General Forum 3 09-28-2012 12:03 AM
ECU flash drei CANADA 8 08-10-2012 01:31 PM
Can the new emissions standards for 2011 alter the ft-86 2jz-gte4life Scion FR-S / Toyota 86 GT86 General Forum 7 04-05-2010 01:16 AM
