Old 04-23-2013, 01:12 AM   #1
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
California emissions questions
Hello!
I was wondering what would make me fail a smog check in California. For my car I would like to swap out my headers for uel headers most likely by Rev works and then also swap out my front pipe for a high flow catted option. I was told by someone that even with a cat on the front pipe I could still fail smog. Is this true for catless headers as well? Ideally I will change out my headers front pipe and over pipe. Is this just a pipe dream (lol) or in theory could I still pass smog?
Cheers!
bdanisi is offline   Reply With Quote
Old 04-23-2013, 01:16 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
removing the primary cat (changing headers) will fail you right away
best bet is to keep your oem parts and re install them before you get a smog
and that's after like 5 years right? or 6?
86_ZN6 is offline   Reply With Quote
Old 04-23-2013, 01:21 AM   #3
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Yea that's prolly the most realistic way of handling this. And as far as the headers go, lol at your insta fail comment. I figured that's how it would work haha thanks
Old 04-23-2013, 01:30 AM   #4
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Unless someone makes a header with a heat shield that looks OEM, then we're all kinda SOL in terms of smog check. Swapping back to stock is really the only option at this point.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 04-23-2013, 01:45 AM   #5
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Forgive me but what would the oem style heat shield accomplish?
Old 04-23-2013, 01:46 AM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
PASS visual inspection
Old 04-23-2013, 01:51 AM   #7
tracerit
Drives: '13 SSM BRZ Limited 6MT
would any of the popular exhausts (perrin resonated catback or milltek catback) fail a smog check? i guess i don't have much to worry since the car is new, but just curious.
tracerit is offline   Reply With Quote
Old 04-23-2013, 01:54 AM   #8
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
By definition catback should never fail anything since it's from the catalytic converter back. But I guess it's not impossible
Old 04-23-2013, 01:56 AM   #9
Tim_Asphalt_FRS
Is it fast? No.
Anything catback is legal as long as its under 95 decibels.
Old 04-23-2013, 01:57 AM   #10
Tim_Asphalt_FRS
Is it fast? No.
Like @86_ZN6 said, it will pass visual inspection. I don't know if it would pass the tailpipe test.
Old 04-23-2013, 02:01 AM   #11
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
While I have the attention of people more mod savvy than I, are their any associated possible long term health issues that could arise from not having a heat shield? I mean for the engine I guess
Old 04-23-2013, 02:24 AM   #12
sw20kosh
Drives: 2013 Black FR-S
A long the same lines of questioning....
Would bigger injectors (for E85 or FI) and a tune be a problem for smog check (assuming no E85 or FI is installed on the car during smog testing, and assuming all emissions equipment is intact)?
Basically what I am getting at is do the injectors need to be swapped back to stock for smog because that would be a major PITA.
Old 04-23-2013, 02:28 AM   #13
Tim_Asphalt_FRS
Is it fast? No.
No. Ceramic coated headers are actually better than a heat shield anyways.
Old 04-23-2013, 02:32 AM   #14
Tim_Asphalt_FRS
Is it fast? No.
For E85: if you're NA with all emissions equipment you'll be fine.
For FI: I'm not sure, because if you swapped everything back to stock except the injectors wouldn't it run too rich? That's my guess. Visual inspection you'll pass. I'm not sure if you'd pass the tailpipe test. I've never gotten that far into the mod process on a car.
Emissions question with a ecu flash sw20kosh Engine, Exhaust, Transmission 2 04-08-2013 01:11 AM
CA emissions ECU flash recall? icemang17 Issues | Warranty | Recalls / TSB 1 04-05-2013 07:46 PM
Massachusetts Emissions ngabdala New England 3 11-26-2012 07:25 AM
Question about smog checks/emissions showbe Scion FR-S / Toyota 86 GT86 General Forum 3 09-28-2012 12:03 AM
Can the new emissions standards for 2011 alter the ft-86 2jz-gte4life Scion FR-S / Toyota 86 GT86 General Forum 7 04-05-2010 01:16 AM
